I have a line (power) to a junction box, and a line out to a lamppost that are currently connected together. It's currently turned off at the circuit breaker. I want to connect it to a timer.
There are currently two black wires, two white wires and two ground wires in the junction box. I bought a GE time switch 15207.
The screw connections labeled from left to right read:
TIMER, TIMER, NC, NO, COM
Where do the black & white wires connect?
This timer has a lot of capability that you don't need, so you have to do a couple of things. I will assume that you are using this switch at 120V and simply want it to turn the light on and off. See page two of the drawing at this link:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15087-15207-56922-Manual-eng.pdf
(this should be the same as the instruction sheet that came with your switch if you bought it new)
First, be sure to set the DIP switches according to the instructions for 120V (all 4 switches "ON").
For your wiring, refer to the first diagram on that page labeled "Timer and Load, Same Voltage, Wired as Single Throw".
The two arrows on the left are the wires from your circuit breaker. The two arrows to the right are the wires going to the lamp post. The top one is black and the bottom is white. With that in mind, you will connect both white wires to the TIMER2 terminal. You will connect the black wire coming from the breaker to the TIMER1 terminal. You will also have to add a jumper wire from the TIMER1 terminal to the COM terminal. Your black wire going to the lamp post should be connected to the NO terminal (that means Normally Open, the other one is Normally Closed.)
This should get you there. Let me know if you have other questions. Be safe, good luck, and thanks for using FixYa. Please vote is this was helpful.
Al K
SOURCE: How to connect a lampost to a timer. GE Time Switches 15207
The following is for the GE 15207 to be operated at 120 volts ONLY(which is what you have):
Make sure the DIP switch is set to 120 volts (all switches in the ON position).
BOTH white wires are connected to the left most terminal. The incoming black (HOT or LINE) wire from the breaker or source is connected to the second terminal from the left.
Also under the second terminal from the left, connect a jumper (using the same gauge wire) over to the "COM" terminal.
Then connect the outgoing black wire (LOAD) to the lamppost to the "NO" terminal.
The two bare grounding wires are twisted together with the supplied wirenut. This is _very_ important for safety.
