Homelite Expand - It 10" Pruner Attachment Logo
Jean Claude Gillet Posted on Mar 26, 2010
Where can i buy a replacement chain for the expand-it prunner [email protected]
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
610
Points
Lawnmower, Small Engine and Outdoor Power Parts from M&D - Site ...where can i buy a replacement chain for the - sacore:green.gif UP08688: UP08688 UP08688 HOMELITE PART UP08688 Replaced by: 6958301 > PS03873 CHAIN,3/8,.043,10 .... HOMELITE PART UT41002A19/UT41002A-19 KNOB FOR EXPAND-IT COUPLER ... ZR10926: ZR10926 ZR10926 HOMELITE PART ZR10926 Chain Saw 16" Ranger 33CC ... ZR15520: ZR15520 ZR15520 HOMELITE PART ZR15520 Pruner Attachment ...
www.m-and-d.com/siteindex476.html - Cached - Similar
Chevy venture timing chain replacement
https://video.search.yahoo.com/search/video?fr=mcafee&p=chev+venture+engine+3.4+replace+timing+chain+video&type=E210US1494G0#id=5&vid=596f1dcac2c889c14537ac1f87deeeeb&action=click
Need a ignition coil for a promac 1000
get make & model number of saw and google.com or yahoo.com or ask.com and type in: want to buy ignition coil for mcculloch promac 1000
or type in mcculloch chain saw parts sales
Replacement tension spring for telescopic tree prunner/loppers
Try a good hardware store for extension springs for the job. Take the broken one along as a sample.
Aug 21, 2012 • Hand Tools
How to crank the tyobi chain saw expander and make the chain saw move
You should be able to adjust the guide bar by loosening the lock handle and adjusting the cam to push the bar out to tighten the chain, If the guide bar is at the end of its adjustment the chain is stretched and needs to be replaced, as I understand your question.
6helpful
Need replacement chain for remington 14inch, EL-1 and remington LNT Limb N' Trim 8. Could you provide me with current replacement chain information for both?
Hi jvaltha,
Here is a website that carries the chain for your EL-1 saw: http://shoppingcart.msservicecompany.com/default.aspx?ext=true&itemid=091374S&size=small The part number is a replacement for the original chain, which Remington must not offer any more.
That same site also carries a chain for your LNT 8 saw, but there are different subcategores, LNT1, LNT2, and 8A and B. I'll paste the address for the page where you have to choose your option: http://www.desaparts.com/remington-chainsaw.html
FYI, You don't need to buy a remington chain to fit your saws. Just buy a chain that is the right length and matches the rest of the specs on your chain, the pitch etc. .050,.025, and so many teeth per inch and so forth. Then you can buy locally.
Hope this helps. If it does, I'd appreciate a 4 thumbs up...keeps me working. Thanks,
Handie Andie
My 4.7 2002 dodge 1500 will not start
i purchased a new timing chain set and the cam pickup was bad on the new cam gear and we had a no start problem. i took the valve covers back off put the old gear on the cam and it started. BUT be careful if u do that you have to wedge the timing chains apart before you remove that gear so the hyd adjusters do not over expand. 4.7 dodge engines **** BIg they made them trying to save gas but the parts and repair over-ride any gas saving i got.
1helpful
My first chainsaw...am seeking general advice on product use etc
Ok to get correct tension on chain, basically loosen it a little until the chain on the underside of the bar is hanging a little... Now start tightening it up again. Basically you want the chain (the main part of each link) to be just touching the the underside of the bar. This will give correct tension... Note that chain does expand as it heats up so it may loose tension... so this is perhaps best done when the saw and chain has warmed a little. Also, new chain will stretch a little naturally so check tension each tme you use the saw.
If you do not know hoe to sharpen a chain properly, it is best to get someone else to sharpen it, or buy a new chain... Eventually all chains will need to be replaced because they can only be sharpened so many times before the cutting teeth become too small to work effectively or safely.
As for oil, if it is an electric chain saw, you only need chain/bar oil. Any good name branded bar/chain oil designed for chainsaws will work well.
Please rate my solution on FixYa!
Thanks.
I need to buy one used 300gb maxtor external hard disk
I have it right here; I returned my cable box. What do you want to do? [email protected].
I have a 97 nissan hardbody 2.4 liter. whenever i crank it from a cold start the timing chain seems to rattle. is this common and should i attempt to have it fixed [email protected]
Buy an upgraded timing chain guide,they are made of neaprene and steel replace chain while your this deep it is probly stretched. the old one is probably broken and peices in your oil pan. been here and done this. this is a factory upgrade.
Mike in Jax Fl.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
