Question about Sony PlayStation 2 (PS2) Console
My child accidentally put a parental code and how can i reset the ps2
  • Sony Master
  • 12,061 Answers
Here is the procedure to reset the parental lock code:
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Posted on Mar 26, 2010
6ya staff
SOURCE:
Master password
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
May 31, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Child lock on in LC-T32HV
Feb 26, 2013 | Televison & Video
Hi i have a samsung tv n im with bell but i forgot my password for parental control... help??!!
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Aug 31, 2012 | Samsung UA60D6600 60in. LED TV
Parental code not working on sansui television
Instructions
Jun 27, 2012 | Sansui Televison & Video
MY CHILD OF 3 YRS OLD ACCIDENTALLY PUT PARENTAL CONTROL ON MY DVD/VHS COMBO IS THERE ANY WAY TO UNLOCK IT
By parental control I don't know if you mean child lock. If that's the case you should be able to turn it off by pressing child lock on the remote control until off shows in the display window.
Aug 07, 2010 | GoVideo DV1140 DVD Player / VCR Combo
I have a ps2 (used) i tryed to put 7444 on the
http://www.techlore.com/article/10505/Resetting-Parental-Lock-Code-on-Playstation-2/
Follow direction precisely.
Mar 22, 2009 | Sony PlayStation 2 (PS2) Console
My nephew put a code for movies, he forgot the code
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under GA_googleFillSlot("TL-IMU-Article"); custom setup.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
Jan 04, 2009 | Sony PlayStation 2 (PS2) Console
Numero de default del control parental del ps2 o como resetearlo
I don't know how to tell you in spanish but this is how you do it Step 1
Turn on your PS2 and choose the menu screen where you would normally enter the password. Instead of entering a password, go to the DVD setup menu. Go to "custom setup" and choose "parental controls".
Step 2
When you are asked for the code or password, press the select button on your controller and enter the number "7444". Now set the parental lock to "off".
Step 3
Press "reset" on the front of the game console to save your settings. When the system reboots, you should be able to view your previously censored games or DVDs. You will also have the opportunity to choose your own password, allowing you to turn the parental lock on and off, either manually or automatically by game or movie ratings.
I often recommend that the parents of older children should regularly reset the password in order to prevent "hacking". Also, try to choose a password that could not be guessed easily. Often, a combination of both letters and numbers works best, as the laws of statistics dictate that more choices equal more failed attempts at cracking the code. Unless your child is exceptionally persistent or lucky, boredom will win out before they guess the correct code.
Dec 16, 2008 | Sony PlayStation 2 (PS2) Console
Tha parental lock code
Step 1
Step 2
Step 3
Jan 23, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 dvd player
If you want to code free parental control then here is the solution when you are asked to put the code press select, then insert "7444" and your code will be deleted and you will be asked to put new code so put a new code, if you wanna completely remove the code, so during the film press select and go to setup and then parental control and select to turn off the parental control
Jan 08, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
