The water level detector pipe could be obstructed / blocked. This thin plastic pipe is at the bottom of the washer and as it fills to the correct level of water the pressure in the pipe activates a water level switch in the washer. Sometimes the air pressure pipe becomes blocked / obstructed or the contacts of the pressure switch become burnt. You can disconnect the pipe and blow through it and the pressure switch is normally factory set and does not need adjusting. Replace it if necessary.
