Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 for an external incomming call or 4 followed by the extension number to pick up a certain extension that is ringing. Thank you.
Testimonial: "Thank you very much!! Problem solved!!"
Without call waiting or a second line, callers will get a busy signal if you're already on a call. This happens at the switchboard; it doesn't matter what type of answering machine you have because the second call doesn't get that far. You can record your own message on the 1739 but, as mentioned above, if you're already on a call then the second call never gets that far.
This could be a setup problem, however I suspect you may have a "smart ring" set up with the telephone company. If this is so then it won't work. If the 3 lines are dedicated, then there is something wrong with the PBX.
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 to answer external incommincg calls. To answer extension phone press 4 followed by the extension number. Thank you
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
That sound is notification of voice mail. This phone does not disconnect incoming calls on answering machine extension so your phone is actually off the hook for hours without your knowledge.
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
