To set date stamp follow the instruction:-
1) Press MENU button.
2) Select REC Menu.
3) Use the up and down buttons to Select Date Stamp.
4) Toggle to the desired opetion OFF or ON.
Note:- Ensure the date & time is set before using date stamp function.
I'm not familiar with this exact camera but most cameras offer the date stamp option somewhere in the menu. Some menus can be intimidating but learning the options will make your camera a more usefull tool.
builderdale
The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
The date stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
You can print the date on image when Postcard is selected. The
date will be printed on your images even if it has not been set at the
computer or printer.
* Ensure that the camera's date/time is set beforehand. * Set the camera to a shooting mode (except (Stitch Assist) or Movie). * Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor. - If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image. - The Date or Date & Time will be embedded into the actual image.
Hit FUNC SET (middle of wheel on back) Hit Right side of wheel to SELECT the mode you would like to have (Auto, Man, etc) Hit Bottom of wheel to get to bottom of Left Menu on screen Hit Right side of wheel to SELECT fifth selection (Postcard 1600x1200)
This is the only mode I have found that supports the date stamp on the Canon Powershot SD600. P.S. Don't forget to set the correct date and time in the screen MENU under the Tools tab!
press the function button and change the picture size to postcard-there is only one setting that allows you to do date and time stamp-once you have rigth pic size setting-pretty sure it says postcard-go back to menu and you will see date and time highlighted on menu
you can only do date and time stamp under function button go to bottom where you can change size of pictures -go to right to W or wide-this is only setting you can do date time stamp on-when you change pic size and go back to menu you will see it highlighted and you can now turn it on-equals about a 2-3 megapixel size picture only-also just leave settings alone and have printer add it-date and time our always in pic data and most printers can add it
Unfortunately, the Date Stamp feature only works with the "Postcard (1600x1200)" setting. Change the shooting mode to Postcard and you can then turn Date Stamp on/off.
You can only set the date stamp in the “Post Card” resolution mode. Hit the “function” button, go down to the resolution selection (L, M, S, W, Postcard, etc.). Pick the “Post Card” setting. Hit the “menu” button and the “date stamp” menu will be active
