There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.. Number 2, you have already addressed. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the Unit, before removing to inspect & clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to where the air
temperature at floor level is colder than at shoulder level in basement applications. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humid-i-stat sensor has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
Hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Marco, There are 4 things than can cause the problem. All are solvable.
1. The air intake filter is dirty or clogged. Remove and clean the filter if necessary. 2. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
3. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
4. Ambient air temperature at floor level is between 40 - 60 degrees.
If
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
Christina, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
If
can happen.
I hope this will help you troubleshoot & solve the problem. Thanks for choosing FixYa.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1& 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If yours is a mechanical unit. Turn the Humidity Extraction knob to Maxi,u.
5. Ambient air temperature at floor level is between 40 - 65 degrees.
If
can happen.
I hope this helps you to trouble shoot & solve the problem. Thanks for choosing FixYa.
Phil, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
temperature at floor level is colder than at shoulder level in basement applicationsl. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
can happen.
Hope this help to troubleshoot the above and solve the problem. Please let me know. Thanks.
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
temperature at floor level is colder than at shoulder in basement applications level. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
can happen.
I hope this helps you to troubleshoot & solve the problem. Please let me know. Thanks.
Edward, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
temperature at floor level is colder than at shoulder level in basement applications . Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
Hope this helped you to troubleshoot and solve the problem without having to make any repairs or replacement of the unit.
There are 5 basic, yet solvable reasons for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a Manually Controlled unit (no LED screen) turn the humidity extraction knob to Maximum. 2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the Unit, before removing to inspect & clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
If
compressor needs to be recharged with refrigerant gas or the humidity condenser sensor has failed. These things usually occur in units that are
can happen.
Hope this helped you to troubleshoot and solve the problem.
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manual unit with no led screen, set the manual control to Maximum. 2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the Unit, before removing to inspect & clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter. The filter should be cleaned once every two weeks.
Most dehumidifiers do not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to where the air
If
can happen.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
On models a lttle later than yours E1, indicates that the air intake filter needs to be removed and cleaned. Probably, the same thing as yours. Before doing so, turn the Master ON/OFF Switch to OFF and unplug the unit. If you wash the filter use warm water and dish washing liquid, Rinse thoroughly and allow to completely before reinstalling. DO NOT operate the unit without the air filter in place.
