If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Testimonial: "thanks alot i will test that."
Bad board.
Please describe, specifically, what your furnace is doing from the time you place your tstat in heat and turn the temp all the way up.
