Nintendo Wii Console Logo
Posted on Mar 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Console freezes up & makes a noise during play
Anonymous
Level 2:
New Friend:
  • Expert 174 Answers
  • Posted on Mar 25, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
174
Questions
0
Helped
39945
Points
402
Wii noises are usually due to either a faulty fan or disk drive. Either one can cause the Wii to freeze up as a faulty fan can cause overheating and a faulty disk drive can slow disk reading down to where it freezes waiting for the data from the drive. It should be serviced or replaced.
1helpful
Won't play ps2 games
take the Ps2 gaming console to nearest Sony service center the problem is with lens it sometimes run quiet well but sometimes got hang you can do one little thing & try it take any of the Ps2 games which are getting freeze while playing take Colgate toothpaste the regular one take a little bit of it & apply on the game disc rub it on the disc & then clean & wipe out with a clean smooth cloth & clean properly after cleaning the disc will look good neat in condition but please make sure no particle is left after cleaning & now play the disc on Ps2 & see if it still get freeze then their is a problem with console better check it at nearest Sony service center for trouble free working
My xbox keeps scratching all discs and wont play them.also tray is loose .when disc is in the screen says reading then makes a noise then says open tray
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally required to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 disc repairs, visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair.
You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
1helpful
When playing games the xbox screen freezes.
www.discREPAIR.ie
Hope this Helps!!
6helpful
2answers
Xbox 360 Freezing during netflix and dvd playback
If you are using a HDMI connection, often the connection will be lost between your xbox and your tv. In my case I simply change to another channel or the other HDMI channel and then back and the secure HDMI connection will be restored.
Nba 09 frezees
I had the same problem with my Xbox, and the answer wasn't good. This is a hardware issue cause by the video coolor not working and the game overheating, making the video freeze totally.
Call 1-800-4MYXBOX, and have your console serial number ready. They might be able to walk you through some basic troubleshooting, but this will most likely end in you needing to send the system in for a repair.
2helpful
2answers
Game freezes and dots appear on screen
I hate to break it to you, but you may have gotten the Red Ring Of Death. It happens when playing a game and it is transmitted through online play through Xbox Live. 3 red lights will appear around the power button when your console has become infected. The Red Ring of Death may have infected your console causing it to shut down. Most Xbox 360 consoles won't turn back on but some do turn back on but they just won't play games, they will freeze up and have the dotted lines and make the buzzing noise. I'm sorry, but I think you may need a new console. You're in luck if it's still under warranty. Hope this helps!!!!
During playing game it freezes up can t even play
man u should  keep ur PS3 COOL and try to make some free space in the HD, but keep it COOL ok
2helpful
2answers
Game Freezing
Make sure the console is out in the open. It needs to vent. Don't place it in a confined area. Make sure any vents on the console itself are not blocked or covered with dust. Sounds like it is overheating.
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
