Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
Posted on Mar 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problems with signal on some channels on tv - Daewoo DP42SM 42 in. HD-Ready Plasma Television
Anonymous
Level 3:
  • Master 748 Answers
  • Posted on Mar 24, 2010
Anonymous
Master
Level 3:
Answers
748
Questions
Helped
290094
Points
2405
Hi
This really require clarification. If you have a weak signal and you're on cable then you need to get your cable company to boost their signal. If you're on an antenna then you need and antenna rotor to turn the antenna towards the station you're watching. You might also need a booster here if the channels are too weak. Good luck
ERROR MESSAGE NO SIGNAL INPUT
What is your TV signal source? Press the Input button on the remote and try another input. (Make sure a DVD player or set-top box is on.) If you are on the TV input, try a different channel. Next make sure that your cables are securely connected to the TV and devices. Replace with new cables to test them. If you use an OTA antenna with a splitter, try a direct connection. (Similarly, if you have an amplifier on the signal, try a connection without the amplifier.)
For OTA or direct cable connections, try accessing the Channel Setup menu and rescanning for channels.
I hope this helps.
(I get some weak channels that give No Signal messages when the transmitter has a problem or the weather is bad. I've also had a signal splitter/amplifier fail and block specific channels by becoming a filter. The direct connection identified the amplifier problem.)
1helpful
Emerson tv 32 in --the channel 7.1 ABC only has picture without sound.
Check the Chanel 7 broadcast signal on the other tv have sound,could caused by the tv broadcasting signal from the tv station itself.Check if ur tv have a function known as S.A.P. make sure it is off,could effected no tv audio problems,because the tv station in ur city or town don't broadcast in that signal frequencies.
I have a Sony KDL-V32XBR1. The turner seems to be having issues. If I scan for channels I only find a few but my other flat panel receives a full range of channel.
U are using a antenna to do a recieving for a Free AIR DTV incomming braoadcasting tv signal channels siganal?Yes.U are using two different tv antennas signals wright?The Sony one just require a stronger and a better antenna signal,not all flat LCD or Plama tvs recieve the same strenghth signals.Some tvs design require a strong or a very strong signals strenght to get all the tv Free AIR DTV braoadcasting tv channels.Buy a better tv antenna design like a Digital amtenna will solved this problems for the Sony tv.
1helpful
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
The picture looks like it's moving in slow motion...
Ur tv incomming broadcasting tv channels signals are pick up and using are Free over the AIR broadcasting tv channels pick up are by a Antena signal wright?Not signals by a pay cables or satalites tvs incomming broadcasting input signals?Yes?This tv causes are low and weak ranges of a tv Antena incomming recieving broadcasting tv channels signal.Buy a better design Antena like a Digital Antena and used it will solved this problems.Plug it in ur Digital Antena and rescan ur Free over the AIR broadcasting tv channels again.
Have problem with many channels while a converter box is fine
Ur tv problems it is the tv antena signal problems.Tries websites like Amazon.com,Ebay.com or Walmart stores to buy a Digital design antena and used it will have no more problems with weak signal or no signal for tv broadcasting channels.
1helpful
My remote scanned all the tv channels (Cable TV, TV, DTV and Cable DTV). The channels that do not show up now are the Cable TV channels. They are there if I type in the channel number but the remote...
U are recieving an using DTV Free AIR broadcasting tv signal wright,get a better antena like a roof or a newly design digital antena for uses.This problems dose not happen to cable or sattellite services,i know this because their broadcasting tv signal frequencies are very strong and very high ranges of a broadcasting signal output for their recieving boxes.
I have a problem with direct tv. It now says Channel not available (no signal).
The direct tv box is the problems and the causes.Unplug,replug the direct tv box about an hour later for the box to reboot and upgraded it software.The direct tv signal should be back.If still not getting a signal for channels,the direct tv box have problems.Call the direct tv customer service,exchange for a new direct tv box.Should solved ur problems.
I can get a picture , but no sound on the TV . What am I doing wrong?
Many RCA TV sound problems are caused by SAP function being activated by TV station equipment that converts Analog TV signals to HD signals. Accidental pressing of the wrong buttons on your remote can also cause this problem.
The incorrect conversions causes the Audio settings to be changed from Stereo to SAP by the received signal.
Solution is to go to Audio set-up in customer menu and change settings from SAP to Stereo. If you find that settings are wrong, change them to "Stereo". Do channel scan if you are using the TV tuner/remote to select channels. Turn off the TV and unplug for 60 seconds. Check the settings again and reset if required.
This problem may re-occur when you select the VHF channel, satellite channel or cable box channel that is causing the problem. It is not a TV fault that can be repaired. The problem is caused by the incorrect incoming signal.
SAP is Second Audio Program, used for second language transmissions.
Second cause may be that the speakers have been turned off in the audio set-up menu.
easyab
2helpful
Vizio pixelation in hd nt all channels
Usually a TV that pixelates only on some channels is a problem with the signal levels coming into the TV or the cable box. If you are using a cable box then definatley the signal is the issue..
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
