Question about Whirlpool Duet GHW9150P Front Load Washer
What is a f9 error?
My washing machine beeps after or before not sure a spin cycle. I cleaned out the drain under the drum and a paper clip was in it but I still get a f9 error.
  • 5,911 Answers
"F09" is an Overflow Condition error. The following link explains how to diagnose the problem yourself:
http://www.fixya.com/support/r3608557-f09_error_code
Read through the information provided and check all the common sense things that you can easily eliminate, first. For more in-depth troubleshooting procedures, refer to the tech sheet that came with your washer. The tech sheet is located inside your appliance. To access, remove the lower toe panel under the door by removing the screws under the bottom front edge (you may have to prop the two front feet of the washer up for better access - a 2x4 works well for this). With the screws removed, the panel will drop down, then come off.
The tech sheet will either be located directly behind the toe panel, or affixed to one of the interior cabinet walls. The tech sheet includes troubleshooting tips, error code definitions, test points, diagnostics procedures and wiring diagrams. You will need to use the tech sheet to accurately locate and perform some of the steps I have outlined.
If you have questions about this repair, please post back and let me know. I hope this helps you.
Posted on Mar 24, 2010
6ya staff
SOURCE:
What is the problem why water does not drain after rinse cycle?
Hello friend, thanks for your post!
I understand that your Electrolux washer is not draining properly. Some possibilities for your washer not draining could be an issue with the drain pump or control panel. You should additionally check the drain hose to make sure there are no restrictions. If your washer continues to not drain properly you should seek assistance from a professional to repair the appliance. I hope this is helpful. -Matt
Aug 12, 2014 | Electrolux Washing Machines
Asko 10625 washing machine wont drain or open
Take the bottom panel off and there is a large drain under the drum. There will be a lot of water that comes out, so be prepared. When you take the drain off, there should be a debis trap in there. Clean this out look to make sure there are no socks or anything in there.
Nov 27, 2013 | Asko Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
We have a MHW2000AWW Neptune washing machine. It is starting to have the same problem that we experienced over a year ago. The washing machine goes through a complete washing cycle but does not perform...
This is probably simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is either a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
OR
You will need to access the debris trap from the back of the machine. If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Jul 10, 2011 | Washing Machines
Hae we have a fisher and paykal washing machine but it wll not start spinning can u help
Run a diagnostic test for the spin cycle. The paper to show you how to run these test is located under the control panel normally two screws on the back of the control panel. By running the diagnostics, it will code if there is a problem and you will know what to check. You can also drain your machine with these diagnostics.
Does your machine beep (because there is a problem) during the drain process but doesn't get to the spin cycle? More than likely your drain hose is clogged. It is very easy to check this. I had the same problem because my machine could not drain properly and would not get to the spin cycle. There was a penny in my drain hose. There is a video on youtube that shows you how to do this (very informative).
Jan 19, 2009 | Fisher Paykel EcoSmart GWL15
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
hold the start button for 5 seconds this should clear previous program. then select drain on your dial. press start as normal and machine will drain. if this does not work the only other remedy is with help, making sure the end of the drain hose is higher than drum at all times take machine outside, lean it back at 45 degrees agaist a wall with a towel or similar covering lid to stop scratching . working from underneath loosen the large jubillee clip that connects the drum to pump drain hose to the drum. As the drum is overfull there is no recepticle large enough to fit under so just let water just flow away. Dry every thing off. make sure you don't loose ping pong ball in filter and make sure filter is clear. refitting is reverse of removal
Mar 28, 2008 | Hotpoint Aquarius WD640 Front Load...
Flashing F-9 and beeping
Check that the filter is not clogged.
Disconnect AC FIRST........******
open the bottom access panel , (3 screws on bottom lip)
remove panel
open the large filter in the center, very apparent
be prepared for water, have mops ,buckets rags, pans ready.
clean and remove all debris.
see if anything when up into the small pump area too.
spin the pump propeller and make sure it spins free.
if you find nothing but water then the main large hose in the center may be clogged, that will take some work to disengage the clips and to reinstall.
Jan 26, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Jul 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,015 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
