SOURCE: camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
SOURCE: My battery is fully charged, camera goes on and shuts off.
this generally happens if you have dropped it. when the message comes. try tapping the camera. if it works then you are lucky. if not then you have to change the lens array. it costs about 60$
SOURCE: my camera shuts off immediately after turning it
Take off the battery and the memory card
Try to wipe the metal contacts on battery with a cloth
Try to put back on to the camera with out the memory card
Try to turn it on
If the camera still have the problem
Try to take the battery out
Try to plug the charger directly on to the wall outlet then plug it in the camera with out the battery
Try to turn the camera on
If the camera has the same issue
Call the manufacturer
SOURCE: Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
