Question edited for clarity.
Question moved to a better category.
Hello Maurice
questions like this really need to model number of model name. Doro make lots of flip phones. There are various ideas here in the links below.
Remove battery to reset.
Your data usage is exceeded.
The text wasn't sent.
If you have the HP LaserJet P2035 (or P2035N), then the LED next to the circle with a small opening at the top indicates the printer ready state. (This symbol/LED is below the triangle with the exclamation mark and above the Go button and light.) If the light is steady, then the printer is ready to use. If the light is blinking, then the printer is processing a job. These apply when no other lights are lit.
The yellow triangle with an exclamation mark will typically be accompanied by a message explaining what's gone wrong. Hopefully it will be self-explanatory - such as a low reservoir for the windscreen washer system.
The triangle with the arrow around it is for the wheel speed sensor. The triangle with the exclamation point is for tire pressure. Low tire pressure would set both of these lights off.
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
that means atention:)
Maybe toner is low. Don't worry and keep on printing until you can. But if you can't print then maybe you have a paper jam. Look for problems with paper and restart printer
pifonski
This light is indeed designed to indicate a low toner condition. Its coming on is triggered not by the actual level of toner in the cartridge, but by a software process that estimates toner use. If you are inclined to refill your own cartridges, you can use install a glass fuse in the little clip on the back of the toner cartridge that will reset the counter, and turn out the light, otherwise the light will stay on. The reset process will blow the fuse, so a new fuse is needed each time a cartridge is refilled. Leaving the light lit does not hinder the operation of the printer, so as long as there is still sufficient toner to print, the printer will operate normally.
