Dont think you want to hook directly to 110 with the motor. I believe the motor runs on DC so I hooked up a battery charger to mine to see if motor was good.
Sounds like the bridge rectifier is bad.to test the motor unplug the motor from unit connect 110 volts to the motor itself and see if the motor runs.easiest way to test motor
Testimonial: "Thank you for the Tech.advise. It now works fine.. R.Doug"
