Computers & Internet Logo
Posted on Mar 23, 2010
No sound from the pc - Intel CMI 8738 6-Channel 5.1 Surround Sound 3D PCI Sound Card (RETAIL BOX) - CM8738
  • Anonymous May 11, 2010
    Need more information about the issue.... as in:
    Have u replaced the sound card?
    When did the issue first occur?
    If you have installed and not able to use from first use onwards, have you installed the drivers?
    Which Operating system is installed on the Computer (Win XP, Vista, 7 etc)?
    Are you using an external speaker or speakers attached to monitor itself?
    Am providing a common troubleshooting doc from HP which normally applies for most of the sound problems. But check if you have connected audio cable from PC to Monitor if speakers are located on the monitor itself.
    Troubleshooting Sound Problems with Monitor Speakers
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    Resolving HDMI Sound Issues with a Desktop Computer
    No sound in Windows 98, ME, and XP
    No Audio Device in Windows XP
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 53 Answers
  • Posted on Mar 23, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
53
Questions
0
Helped
14860
Points
74
Hi Michael,
There can be many problems, why you can't get any sound from your computer.
If you didn't already check them with another audio source or by connecting to another computer, check your speakers and earphones/headphones to make sure they are not the cause. A very common mistake that people do, is to accidentally connect the speaker cable (one with the green connector), to the Line-out or Microphone socket on the back of the computer. Just double-check to make sure, this is not the cause of the problem.
If the speakers and headphones work fine with the other audio source or on another computer, you may try doing a system restore to a previous state. You may want to create a new restore point first, before doing that, so that if the previous state is worse, you can return the computer back to the present state. To know more about System Restore, go to this link or copy/paste it into your browser: http://en.wikipedia.org/wiki/System_Restore
If system restore didn't work for you, then, look carefully on the Windows Taskbar (near the clock). Do you see the speaker icon or does it have a red cross on it? Touch it with the mouse pointer. Does it show any error message? If yes, then most likely the sound driver is missing or corrupted. You can try updating the drivers, other than with Microsoft update wizard, either by manually downloading the drivers from your computer manufacturer's page, or with an easier method.
Here's the easy method to get or update your sound drivers:
You could try to use this driver scanning tool, which would scan your computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free driver scanning tool from here: http://xpdrivers.com/index.cfm or directly from this link: http://xpdrivers.com/download/download.c… (copy and paste the link, if you can't click it).
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
For Windows XP Driver Files and How-to Resources, visit http://xpdrivers.com
Hope that helps,
Regards,
Raspal
I use attached the pc on tv but i didi not here any sound please tell me sound pin cable attached the tv?
Hi sahazada pak,
As i know, TV set not support sound from PC input.
If you want here sound and still working with PC, you should use HDMI or DVI input from your PC out. HDMI has support image and sound in one cable. DVI only image without sound. if you use DVI , sound pc should connected to audio in.
Good luck.
Hooked up to TV but can't get the sound leads to work. No sound from TV?? Can anyone advise please? Lorna x x x
u cant get sound from TV linked to PC.....as the PC's sound system use a RF connection...it does not have a amplifyer...the sound system travel in two formats....non-amplified and amplified....the sound sent from PC/Laptop it's already amplified...but the TV connector can receive only non-amplified signal(say from a DVD player, camcorder, music system etc)...it cant process the signal from PC/laptop......you can connect ordinary speakers ment for laptop to the sound out jack in the PC/laptop and use the TV to receive the video signal....from PC
hope this helps
Kris
1helpful
My dv9700 has no sound anymore. The message says, "no sound device found"
reinstall your PC's sound drivers using the drivers disk which came with the PC.
Alternatively, go to the HP website and use their automatic update service to update and reinstall your sound drivers. www.hp.com/support
If reinstalling the sound drivers fails, you may have a logic fault with your sound system, take the PC to a professional for this as this is part of the mainboard.
2helpful
2answers
After formating my pc i hear no sound..My pc is Windows XP Professional Service Pack 2 (build 2600) Help...
After PC format, you now need to put all the required pc drivers like modem driver, sound driver, LAN driver, WAN Driver, Camera Driver and other driver software. Maybe you miss this software. Check your device manager if you pc is not reading the sound card hardware because you have not install the sound card driver to activate the sound card.
1helpful
3answers
No sound coming from computer. speakers work tested on other stereo
The speakers may work but you probably have no sound driver. It is a sound driver that makes sound come from your pc. Type in your computers name and model on google and download drivers for your pc. If it is not drivers then your sound card is faulty.
Accidently deleted sound for my PC.
you don't need to buy a sound card just go to your PC(brand e.g. dell,hp..etc.) website>support>enter your pc model>download your sound driver and intall.
4helpful
8answers
I have no sound in my pc!
change from windows to xp,but sound driver was not loaded/installed so there is no audio sound in
my pc.from where n what driver to install in window xp for free.kindly
advice n thanks.
1helpful
3answers
My pc sound system has a bad echo..
try uninstalling sound drivers and reinstalling them (or newer)
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
