Tablets & eReaders Logo
Posted on Mar 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ram is there any ddr1 2gb rams are available if available what is the costs of 2gb ram uf not what is the cost of ddr1 1gb ram
Anonymous
Level 2:
Guru:
  • Expert 377 Answers
  • Posted on Mar 15, 2008
Anonymous
Expert
Level 2:
Guru:
Answers
377
Questions
Helped
340104
Points
842
Dear harris
the cost of 2 GB sodimm ddr2 pc 5300 memory is about US $40.75
and for 1 Gb it's about US $ 24,7
oke
cropp
Is battery removable? replaceable? available for purchase?
Yes you can either search one on the Internet, or I think Amazon has some you can choose from
Is a cracked screen covered under the warranty?
Hi Abby,
Most manufacturers do not warranty "damage from handling, misuse, neglect, accident" as that is not they way their products are intended to be used. Warranties usually apply to defects in workmanship and failures not associated with the list of things above.
This is why 3rd party warranty companies such as "Square Trade" came into being. These companies will offere to extend your manufacturer's warranty to 2, 3 or more years and offer protection from the types of problems they do not cover - drops, submersion, breakage, etc. Cost is based on the product, cost, length of warranty term and extent of coverage. As long as it wasn't stolen - return all the parts of the covered device for repair, replacement or reimbursement. You can also usually insure these products as a special "rider" on your homeowners insurance, too. Contact your agent to learn about the availability and cost of this coverage.
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
How to restore this tablet back to factory settings as daughter set pin no. password in error and we can't remember what it is. thanks
start your tablet when network connection is available then it's auto connect and go to the forget password and you can login your registered id then it's open ....
2helpful
Irulu
Can one upgrade the Ram (currently 512mb) on my iRulu tablet to 1gb. The tablet is a 9" running 4.2.2 (Jelly bean). If yes, how do you access the ram in the tablet.
I'd like to upgrade the hard disk to 64 Gb. With one I need to buy? Thanks Arie
Might just want to buy the NEWER CFU1!! It'll cost you about $960.00 to upgrade yours!!
http://www.provantage.com/panasonic-cf-wsdu1031~4PSO90TV.htm
2answers
Can't find ram slot!
There are laptops that do not have two slots for RAM. the EEE Pc's for example only have one slot.
3answers
Can I install windows 7 on a panasonic toughbook cf-18 tablet
I don't thank they have it out for tablet yet. Wait a bit and they should.
1helpful
2answers
I bought the proper matching two 1Gig sticks of memory to upgrade my 2G mHz TC4200. I installed them and it wouldn't boot, so I swapped back the 1G stick to the original 512mHz chip and it booted. Then I...
Ok, Rob, did you buy the memory from Compaq/HP? Or is it a 3rd party set (ie. Viking, PNY, etc.)? Sometimes, Compaq/HP computers are VERY picky about the specifications of the memory that the mother boards will use.
If you bought them from a 3rd party vendor, I would recommend taking them back and exchanging them for another brand or even just another set of sticks, but, before we go that route, let's try something else.
Install a 1gb stick and the 512Mb stick and then go into the BIOS and see how much ram is being registered there. If it reads all 1.5Gb of ram, then we know it is something else, if not, then we have somewhere else to look.
Assuming the BIOS registered the full amount of ram, try removing the 512Mb stick and then boot the computer, enter the BIOS and see if it is reading the 1gb stick properly. Assuming it did register the 1gb properly, swap the 2 1gb sticks out and repeat. If it did NOT register the lone 1gb stick, try moving the 1 gb stick to the other socket, and checking the BIOS again. If that works, then swap the 1gb sticks out, repeat the BIOS check.
Assuming that after you swap out the 2 sticks and they both work as lone sticks, go back into the BIOS and look for an advanced page or an option to turn on a "Diagnostic Mode" or "Memory Test", and run the memory test on each stick- one sitck at a time, to see if there is a minor/major memory addressing issue, with either stick.
If they both pass individually, then, try reinstalling them both together and check to see if you can reach the BIOS with them both in place. If not try putting the 512 in the 0 or first memory slot and the 1gb in the second slot, then repeat the memory test, swap the 1gb sticks again, and repeat the memory test on the second stick- (the thinking here is that if it is not the memory sticks themselves, perhaps it is the motherboard or one of the sockets for the ram that is bad).
If you can reach the BIOS with both 1gb sticks in place, but, not actually boot to the operating system, then it is possibly a timing issue- this SHOULD BE AUTOMATICALLY configured, but, if you are an overclocker or a "performance wonk" you may have changed a relevant setting in the bios that controls the speed at which the memory and the processor interact. Or it could be a problem with windows hardware monitor not accepting the changes to the amount of memory in the machine. To test this possibility try going into "safe mode" at boot up, after the BIOS screen/Compaq logo has come and gone.
If you can boot into safe mode and not into regular mode, it is a problem with something in windows. Sometimes, just booting into safe mode alone will fix it, sometimes, it is necessary to run the restore DVD on the computer to fix the problem windows is having/ or alternatively reinstall windows without running the restore DVD, using this method will usually fix windows, with out deleting all of your data. You might have to reinstall a few programs afterward, but, your pictures, mp3s, document files, etc. will still be on the drive. Running the restore DVD almost always deletes your data, so USE THAT SOLUTION AS A VERY LAST RESORT, ONLY AFTER YOU HAVE TRIED EVERY other option I have given you.
Good luck, and hope this helps.
To know good hard disk
I think that Western Digital Hard discs are reliable with affordable cost. But if you put a little money more Seagate offers better stability.
DDR1 or SDRAM?
Either or else I think Transcend is your solution and it is better to go to 2GB of Ram to see better improvements.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
