My Baumatic EL 1000 electric oven has stopped working. The grill works but the oven does not. When I turn it on it gets luke warm but not hot enough to cook in. Who would be a good company to use to have the oven repaired? I think it may be quite an old model.
I've had to choose an incorrect product name below since the EL 1000 was not listed.
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
SOURCE: My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
SOURCE: Oven has stopped heating up
Hi.
This oven should have two elements.
If both broiling and baking element are not heating, then
the most common fault causing the problem is a defective temperature
probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in line
on the circuit from electroning oven control to baking and broiling
element.
When the probe fails, it will affect both baking and broiling function.
The
temperature probe is tested reching the probe, cutting or disconnecting
its wiring, and testing the probe at room temperature, with a
multimeter set on impedance at Rx1. If the multimeter reads no
continuity (circuit open), then the probe must be replaced.
If
the temperature probe is good, then parts that may be responsible for
the fault are oven electronic control and wiring. Having both elements
failing at the same time would be rather unusual.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Testimonial: "Thankyou very much for your help.Im off to buy an element first thing in the morning. Thanks again"
SOURCE: baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP
THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
