Encore Mavis Beacon Teaches Typing Deluxe 20 Full Version for PC  Logo
Posted on Mar 22, 2010
Mavis Beacon 20 moving a user file
I have Mavis Beacon Platinum 20 on one of my computers. I know my user data is in the prefs.dat file. I want to use my file on another computer that has the Mavis 20 program on it along with about 3 other users. My question is how do I move my file over without deleting the other users?
  • TariqTD
    TariqTD Sep 23, 2019
    I am making $165 an hour working from home. i was greatly surprised at the same time as my neighbour advised me she changed into averaging $ninety five however I see the way it works now. I experience masses freedom now that i'm my non-public boss. that is what I do......????COPY THIS SITE????
    HERE?..................www.tips.cash61.com
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2044
Points
First add yourself (or have an admin add you) as a user on the 2nd computer.
Login into your account and start Mavis Beacon.
Create a name and do an activity or two.
Exit Mavis Beacon and open your My Computer icon
Navigate to the following folder:
C:\Documents and Settings\YourUserName\Application Data\Broderbund\Mavis\
Now delete the existing prefs.dat file and copy your prefs.dat file into the "Mavis" folder.
Restart Mavis Beacon and you're ready to go.
  • Anonymous Apr 09, 2013
    The previous poster didn't really answer the question, since the OP presumably wanted to move over her accumulated user data, not simply create a new profile on the new machine. Unfortunately, it looks as though it's not possible to do what is being asked for, because Broderbund intentionally obfuscated their data and set up their file management in an astoundingly stupid way. In order to use your old data and the newer profiles, you'll need to maintain two separate prefs.dat files. By default, Mavis Beacon saves these in the Users folder, under the individual user who is logged in, so you could create a new user profile on the computer. Otherwise, you'll have to manually copy and paste each time you want to switch Mavis Beacon users.
  • TariqTD
I need mavis beacon that is compatible with dell inspiron mini.
You will need to know the operating system or model number to determine which version of a Mavis Beacon product is compatible with the Inspiron Mini. The Inspiron Mini 9 came with Windows XP. The Mini 10 1010 could have XP, Vista or Windows 7. The Mini 10 1012 came with XP, Windows 7 or Ubuntu Moblin. The Mini 12 1210 came with XP or Vista.
Mavis Beacon Teaches Typing v2 , http://www.broderbund.com/p-952-mavis-beacon-teaches-typing-powered-by-ultrakey-v2-personal-edition.aspx , should work with Vista or Windows 7. This is the current version and works with Windows 8 and Windows 10. Mavis Beacon Teaches Typing version 18 and version 20 Platinum both work with XP and Vista.
I hope this helps.
Mavis Beacon Typing Tutor Platinum 20 shows minus wpm in progress summary even though I average 45-50 wpm,
If it's pirated thats your problem. the patch may have changed the wrong bytes in the exe file
If it's not......
try a re-install of the software if that doesn't work i'd send their product support a message at this link
http://www.broderbund.com/store/broder/Content/pbPage.ProductQuestion
1helpful
3answers
Mavis Beacon Teaches Typing 17 Deluxe Does not start
Assuming you have not switched to Windows Vista with the new hardrive - as Mavis Beacon 17 does not work in that platform - then-
it sounds as though the file is corrupted. I would uninstall and reinstall the product. Unfortunately, difficult to do with out a cd or good original disk to start from. If you have your order number or purchase numbers when you bought your download, then customer support should help you get a clean download.
Here is some information on system configuration- it is similar for the setup of Mavis beacon 17
http://www.broderbund.com/store/broder/Content/pbPage.ProductSupportMain
2helpful
Mavis Beacon 18 does not save users from log-in to log-in
C:\Documents and Settings\All Users\Application Data\Broderbund\Mavis Beacon Teaches Typing 16
Top Encore Computers & Internet Experts
k24674
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
