If you have top clearance you can find 1/2' conduit pipe (elec.) cut 4' you need three. Put on floor in front of piece lift just enough to place pipe1 under as far as you can to take weight and roll on -place next pipe and so on. Be careful of you fingers! You can steer it if you get good at it.
GOOD LUCK BRUCE
SOURCE: I need to move my body solid G4I to another room,
first disassemble the chest press then tie wrap the cable to frame. pull the weight stack off then tie wrap weight stack cable then remove rear base all away to where the front seat is attached now you should be maneuver to the other room
