Question about Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
I have USB cable attached to tv and DVD player and
I have USB cable attached to tv and DVD player, the alert (blue box on screen) won't go away. how do get the blue box to go away?????
  • 443 Answers
Connect the DVD to TV with HDMI or component video, don't use USB, USB on the TV is to insert a flashdrive/thumb drive to display a slideshow or download music.
Good Luck !
Posted on Mar 22, 2010
6ya staff
SOURCE:
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
I own an iview 2600hd dvd player and im trying to hook it up to my sony trinitron tv...however, no matter how i switch my cables, the dvd player just won't show any picture or audio on my tv...and when...
Try new cables. RCA cables have a tendency to have bad connections internally. Also, triple check that you're on the right input and the wires are properly connected to the DVD player. If all that fails, try the DVD player on a different T.V. and something that uses RCA cables on your T.V, such as a cable box to make sure the input jacks on the T.V. aren't bad, and the DVD player isn't bad.
Through out all of this troubleshooting, you should manage to get the DVD player hooked up.
Jun 20, 2011 | Televison & Video
I just got cable and a new vizio tv.. the tv is fuzzy, i was told to use a HDMI 1 cable from the tv to the cable box. But the cable box doesn't have a place to hook the cable up
Are you sure you have a HD cable box? If it is it should have outputs for component video (Green/Blue/Red/White/Red) which can be attached to the TV and will still provide a very good picture.
If the cable box only has RCA outputs (Yellow/Red/White) then you do not have a HD cable box and in order to take full advantage of the capabilities of the new TV you should contact your cable provider and ask about getting a HD cable box.
Good luck....
Dec 27, 2009 | Philips Magnavox DVD/VCR Dual Player
Black box on JVC screen
a black box is covering my tv screen except for around the edges. I can use the dvd player, but i cannot watch cable. it is as though there is a security feature to block tv, but i cannot get it to go away!
Jul 11, 2009 | JVC AV-32D305 32" TV
Blue screen
Are you using component video cables? If so, check that these aren't loose on either end. Next I'd consider that whatever video cable/input might be bad, and switch cable or cable type... i.e. switch from component to HDMI or vice-versa. Then change up the source (cable box versus DVD player). If you're still seeing blue at this point, the TV internals are the bad.
Jul 23, 2008 | Panasonic TH-50PX75U Plasma HDTV
Plasma screen turns RED 600u panasonic 42''-- 2 yrs old.
sounds like a problem with the plug out put on the dvd player take it to a tech and have it checked or test it on another tv
Dec 21, 2007 | Nintendo Wii Console
Sony BRAVIA KDL-46W4100 46 in. LCD HDTV Logo
153 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
