Try to take the phone apart and clean the charge connectors and the mainboards charge connector plates with isoprophanol and let it dry. this will take the oxide/dorrosion away from the connectors
and make it possible to get contact with the mainboard and the
battery will be able to charge again
Possible that the charger is deficient in voltage and so is not delivering the required current for the battery to charge. You need to use a multimeter to check the charger, connect and measure the voltage at the battery terminal on the phone. It can also be a weak battery or shorted battery they can also show the symptom of no charging.
Ideal to get another charger battery from a friend to confirm before you buy one.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Be sure that your battery is ok! Look and try to insert a good battery. If still...:you need to open your phone then clean the charging terminal contacts.
Yes that is software problem, you need to reflashing phone firmware. Some tools and Software you need ; Nokia Flasher cable, Nokia tool Software, Nokia flasher software, a proper Nokia Firware ( NHM-5)
mine stop charging sometime ago, and I switched to a nokia 3310 charger and its been working fine since. might be a little tight going in at first. good luck.
If the battery was draining too quickly, and a new battery does the same thing, it is very possible that the phone has a defect that is causing it to draw too much currnet. This you will not be able to service yourself. You will have to send the phone out for service.
Considering the cost of servicing a phone, it may be worth to simply get a new phone.
