I have installed a selectable 12/24 volt trolling motor on my boat. When in the 24 volt mode, the motor works well for about 3-4 minutes the loses all power. After about a 15-20 minute "cooling off period" the motor will work again for about 3-4 minutes. In the 12 volt mode, the motor works well all the time, only at about half the speed of the 24 volt mode. Why is my motor losing all power in the 24 volt mode?
No. you can put in extra batteries and use it, but you must remove you charging system from them to use it that way. Not really practical.
SOURCE: wanting to install motorguide 24v trolling motor
It should but may not run at it's intended potential. It may also run your battery down a lot quicker.
