Re: My jabra 0TE1 bluetooth is not recognized by my...
No, bluetooth means compatible. Have you set your headset to discovery mode before you looked for it with your phone? I think you hold down the main button until the light stays lit.
take another look at the instructions for pairing them. Either one should work fine with your phone. You're probably missing one step (like adding the 0000 code when asked).
Hi eidref,
Any Mobile Phone should be compatible with your Jabra BT headset, as laong at the Mobile phone has Bluetooth that will work.
See the Manual but most likely it will not say since it is compatible to any Mobile as long as the mobile is Bluetooth capable.
Have a nice day.
bluetooth headsets are compatible with any phone that has bluetooth to connect just while its off, holding down the
power button untill a constant red light comes on. then searching for
the headset
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Please suggest a solution for Samsung SGH-620 mobile Ringtone is stopped while change body of mobile it may be fitting mistake so please suggest to solve the problem by myself at the earliest in fact all systems are still working except ringtone only.
Regards,
Rajendra Pandya
Bhayander(west)
Hey guys,
hold the button pressed for 6 sec. until led is solid.
then search bluetooth devices on phone
click on Bluetooth headset
insert '0000'
press OK
now it should work, or check http://jabra.com for compatibility.
Best wishes,
htmlfreak.
Jabra headsets sometimes have a different way of being put into discovery mode. Most headsets just have you press and hold the big call button on it. Some jabra headsets require you to JUST hold down both volume buttons and some other jabra headsets require you to hold down ALL buttons on the headset to put it in discovery mode (or pairing mode as they sometimes call it)
Try of those combinations ... The light will stay solid when it's in discovery mode... Once the light is solid THEN have the EnV search for headsets.
