Lights come on but no fan sound, or video. The lights are on steadily. I think the laptop had something spilled on it. The keyboard was sticky. Any possible solutions while the laptop is apart would be helpful
If there is a liquid damage on the laptop then its gonna be for out of warranty service which may cost you 499 - $699.99.. if none, then you may call sony for troubleshooting or visit their site for free chat support for 15mins.. go to the link and click get live support
The first step to replacing your laptop keyboard is to remove the screws from the back of your vaio vgn-fe880e/h. Sometimes your laptop will have a picture of a keyboard next to the screws that need to be removed. Otherwise, see your laptop manual for details.
Above the laptop keyboard for sony vaio vgn-fe880e/h, you have a cover panel. If required, remove this part to easily access your keyboard. If you have screws above your keyboard, remove those screws.
Now that you have removed all the screws, you are ready to remove and then replace your new laptop keyboard.
To remove the vaio vgn-fe880e/h Keyboard, take a thin object and pry the keyboard out between the keyboard and motherboard. Be careful when removing the keyboard.
Now that your keyboard is loose, simply disconnect your keyboard. In order to disconnect the keyboard, pay attention to the keyboard connector and connector cable. Unlock the connector cable device and remove your laptop keyboard. Your sony vaio vgn-fe880e/h connector cable should be easy to remove by simply sliding it out.
Now that your keyboard has been removed, get ready to install your new laptop keyboard. Look at the back of the keyboard. If you see any screw holes, you will have a good idea of where to place the screws back in at the bottom of the laptop.
Connect your laptop keyboard for sony vaio vgn-fe880e/h to the motherboard keyboard connection slot. Secure the keyboard cable. Now turn your keyboard in place, and align the grooves on the bottom of your keyboard with your palmrest or plastic bezel. Secure your laptop keyboard in place, make sure it fits properly and is snug. Now simply place the screws back in place.
It sounds like you may be having a video related issue. These issues may indicate that you have a problem with either your video card or your lcd screen. To isolate the issue, you have to connect an external monitor to the VGA port of the portable system. There should be an S2 button on your laptop which should allow you to switch videos. Press that and if the video appears on the monitor, then it is an issue with the LCD screen. If nothing happens, you have a video card failure. These are due for replacement already.
pls consider changing ur RAM issue will be resolved most likely ok let me know , there is strong chance ur RAM is faulty, if power comes but unable to start the system u see blank screen and no hard disk activity and light blinking then it is the RAM issue
pls rate me if i solved ur problem or explain ur problem in detail
