Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
