Hi peepz, folks, lads, boys girls & girls i had my Nokia 6300 fixed & updated under warranty (the shop cannot / wont help) now my 2GB micro sd Sandisk memory card is asking for a password / pin no please please please help i have over 400 music tracks & nearly as many pictures of my babies many thanx Rick.
I have nokia 6300 handset. it's phone memory is locked. i donno the password? how can i use the phone memory?
I have memory card of 2gb scandisk when i inserted memory card in mobile it shows unable to open can u help me
You can recover the password. The best way is to download a file manager to your phone. I use 'Best Fileman' from http://www.smartphoneware.com/ It's for series 60 and 40. The trial version should be enough, it's only £5.60 anyway.
In the file manager you'll find under- C:\System\mmcstore -the file you're looking for, you have to rename the file- mmcstore.txt -then send it to another mobile (best way) or your PC via bluetooth, open it on the other phone and your password will be revealed.
Rename the file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
Clear enough?
This is the URL for it;
http://www.smartphoneware.com/fileman-fo...
If they don't have it how come it's on my phone, I use it regularly.
Best FileMan - User Guide
File Manager gives you full control over the file system. With the help of this utility you can browse your folders, copy, move, rename files and folders, view and send files via Infrared and bluetooth and much much more.
If you need a convenient and whole functional File Manager, then try FileMan and you will not be disappointed in your choice.
General functions:Operations:
Copy - copy selected file(s) or/and folder(s) to buffer for future "Paste" operation;
Shared copy - allows to copy shared (owned by other applications) files;
Cut - cut selected file(s) or/and folder(s) to buffer for future "Paste" operation;
Paste - paste copied or cuted file(s) or/and folder(s);
Rename - rename file or folder;
Properties - show detailed information about files(s) or/and folder(s) or disk etc;
New folder - create new folder;
Delete (hot key: (C) ) - delete all selected file(s) or/and folder(s);
Set Attr - sets file(s) or/and folder(s) attributes, allow recursive operation that processes all files in subfolders;
Add shortcut - assign folder shortcut. With this feature you can navigate fast in the FileMan. e.g. If you assign shortcut to "Shortcut 'Abc+1'" you can press Abc(Pen)+1 to open this folder;
Add to pinbaord;
Open with;
File(s) or folder(s) selection:
Mark/Unmark;
Mark all;
Unmark all;
Invert selected;
File searching;
Find;
Advanced find;
File searching;
Find;
Advanced find;
Send file(s) via;
Infrared;
Bluetooth;
Email;
MMS;
Sort order;
None;
Name;
Extention;
Size;
Date;
Type;
Descended;
Folder first;
Other features;
Mailbox filter;
Infrared On;
Full screen mode;
Use mime recognizer to retrive file icon;
Show/hide system folder;
Show/hide rom drives;
Custom right button acction;
Keyboard layout for different series 60 devices;
hi. The file (mmcstore) does nt show in :C\system. Im using a nokia e65, my 6303 went in the washing machine and on the 6303 it never used to ask for password. I set a password on the 6303 a year ago and have since then forgotten it. Pls help, i have alot of music and pictures on my mmc!
best fileman doesnt want to install. Is this because i have S60-3rd edition on e65?
ok. I downloaded best fileman for my E65 bt how do i install it? It says 'installation of best fileman90.sis not supported' what do i do?
but problem is that .SIS is not supported for your mobile occures when installing on phone
I paid for the bestfileman software from smartphone.com but never received it from in either an email or disc so i had the idea to get a micro sd adapter to mini sd adapter put the memory card in my Nokia N80 & managed to format it that way but i did lose all my 35 java games & pictures but i had those on another memory card which i had forgotten about many thanks for your suggestion i know my solution is not perfect but saves on buying more memory cards Dickytricky.
Find your solution from the list,
Nokia 6300
Codes:
Software & Hardware Problems
Find Solutions for other Nokia Phones:
Nokia N95
Nokia N73
Nokia N70
Nokia 6600
All the other Nokia Phones.
Bia r chul chire anti bandhe gocha korle hobe
How do i pair my headset (motorola H700) in nokia 6300???
Hi folks i emailed www.smartphoneware.com to check if they're progarms / software would work & they said NO they have nothing like that so if anyone else has a better solution i would be very grateful thank you very much.
i created a password for my nokia 6300 one month ago and now i forgot it... i can get into it but i must delete the password because everytime i connect it to the computer, the computer stops working and if i connect it to another phone, it asks me for a password.......so please help me find the solution for my conflict :S:S
same Problem
PASSWORD OF NOKIA 6300 MEMORY CARD
is there any code fo r to remove my password
& updated under warranty (the shop cannot / wont help) now my 128mB
micro sd Sandisk
i have over 10 music tracks and mch more data.........pls help
is there any code to remove my password
i had my nokia 6300 upgrade
from a nokia service center and when i open the memory card it was locked and asking for a password.i havnt put any password on it and now i could not open it.HELP!
forgot phone pin
it's a joke my 2gb sd card is doing the same i dont no what to do bout it does any one know
