I have a Sony TC WE305. When I insert a known-good cassette into the 'A' deck & press play, the tape transport doesn't turn. When I press FF or REW on the 'B' deck the capstans turn but when I put the known good tape in there and press play the capstans don't turn. Any ideas why?
FF and Rewind are functions of the reels, not the capstans. If the reels fail to rotate in response to capstan-driven tape motion the unit will assume a broken tape or end of tape. I think you have a mechanical reel drive system failure. Take it to a shop for evaluation and correction.
Testimonial: "This makes sense to me...thanks for taking the time to answer this."
A Tv repair shop carries a large stock of belts, probably a good place to start. The other option is order from Sony online and ask for the Technical Department.
This condition, regardless of which way the tape is moving, is caused by the failure of a rubber pinch-roller to trap the tape between capstan and the passive roller.The speed is then caused by the part of the drive driven by a small belt and a clutch that should only keep a small amount of tension on the tape in ensure clean rewinding of the tape after it has passed the head. Lubricant in part of the transport's moving parts or a dried-out rubber roller may be causing this.If you want to try to clean the pinch roller, don't use alcohol since this can further harden the robber.Use a clean fiber-free cloth or paper towel wetted with a LITTLE naphtha and turn the roller on the wetted area. If you get some dark smudging, the treatment is working.
Define 'skip' in the context of your CASSETTE deck.
Poor audio is usually due to damaged media or dirty transport (heads, pinch rollers and capstan).
You can see the tape inside the cutouts of the cassette shell. It should be perfecly smooth and the edges straight. Use reflected light to evaluate it. Edge damage will affect the Left Channel most.
Dirty heads will cause loss of high frequencies first.
The transport, well, if we need to explain it to you then we KNOW it's never been cleaned.
Muffled sound is either damaged media (is it mostly the Left Channel? Multiple tapes or not?) or dirty Playback Head. Clean the heads and transport.
Please define better what "won't record" means. Tapes to be recorded need to have the little tab in the corner of the cassette shell present to allow the machine to enter record mode.
Follow the left channel lead to where it joins with the PCB. Use a pointed tool and prod connections if you get a buzz then that stage in the amp is working. I suspect you will find it leads to a IC that might cause the fault. If you find it buzzers on the right but not left, then it's gone. PS don't short pins. If you can get hold of a signal injector it will make things easy.
Be careful and good luck.
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
