Likely uneven feed (top thread snagging on spool). This machine has a horizontal spool so be sure the the spool cap is larger than the spool and double check with the manual on which way the thread is supposed to come off the spool... I believe it should fall forward, so if not then flip the spool.
Could also be top tension is extremely high.
Or possibly the bobbin thread has no tension... be sure to hold the bobbin spool with right index finger while you guide bobbin thread into slit. You should feel the bobbin thread slide underneath the bobbin case tension spring. See machine instructions.
Sewing machine operator can often help themselves when their machine does not operate properly. Here are some simple instructions, which if properly used can save time and mechanics service calls. TROUBLE;UPPER THREAD KEEPS BREAKING; This could be trouble; >Do this; 1.Top tension to tight >loosen tension 1 turn 2.Machine improperly threaded >check threading 3.Thread twisted on guide post > " 4.Thread twisted out of tension > " 5.Take up spring bent or broken >Check action of spring 6.Thread jumped off pull off finger >Check threading 7.Needle bent or burred >new needle 8.Bad cone of thread >try another cone TROUBLE;LOWER THREAD KEEPS BREAKING; 1.Bobbin tension spring to tight >Loosen tension slightly 2.Bobbin threaded wrong >check threading 3.Bobbin wound to tight or uneven >try new bobbin 4.lint or thread on bobbin case >clean inside case 5.Lint or thread inside hook >clean inside hook 6.Bobbin case nicked bent or burred >check/change case TROUBLE;MACHINE STARTED SKIPPING STITCHES; 1.Needle bent or burred >change 2.Needle set in crooked >Check 3.Thread jumped off take up spring >check threading 4.Thread jumped off pull off finger >check threading TROUBLE STITCHES SHOWING LOOPS; 1.Forming loops on top of cloth >Tighten bobbin tension or loosen top tension. 2.forming loops on bottom of cloth >Tighten top tension 3.Bobbin placed in case incorrectly >remove and replace 4.Bobbin thread slipped from under >check threading of tension >bobbin case 5.Lint or thread in top tension >clean between tension discs
Please just add a comment if you did not solve your problem by doing these procedures. If this solution helps you please do not forget to testify and rate me...Thank you so much for using fixya!!
A sewing machine operator can often help themselves when their machine does not operate properly. Here are some simple instructions, which if properly used can save time and mechanics service calls. TROUBLE;UPPER THREAD KEEPS BREAKING; This could be trouble;================Do this; 1.Top tension to tight================loosen tension 1 turn 2.Machine improperly threaded=========check threading 3.Thread twisted on guide post========" 4.Thread twisted out of tension=======" 5.Take up spring bent or broken=======Check action of spring 6.Thread jumped off pull off finger===Check threading 7.Needle bent or burred===============new needle 8.Bad cone of thread==================try another cone TROUBLE;LOWER THREAD KEEPS BREAKING; 1.Bobbin tensionspring to tight=======Loosen tension slightly 2.Bobbin threaded wrong===============check threading 3.Bobbin wound to tight or uneven=====try new bobbin 4.lint or thread on bobbin case=======clean inside case 5.Lint or thread inside hook==========clean inside hook 6.Bobbin case nicked bent or burred===check/change case TROUBLE;MACHINE STARTED SKIPPING STITCHES; 1.Needle bent or burred===============change 2.Needle set in crooked===============Check 3.Thread jumped off take up spring====check threading 4.Thread jumped off pull off finger===check threading TROUBLE STITCHES SHOWING LOOPS; 1.Forming loops on top of cloth=======Tighten bobbin tension ======================================or loosen top tension. 2.forming loops on bottom of cloth====Tighten top tension 3.Bobbin placed in case incorrectly===remove and replace 4.Bobbin thread slipped from under====check threading of tension===============================bobbin case 5.Lint or thread in top tension=======clean between tension discs
