Canon ZR45MC Mini DV Digital Camcorder Logo
Posted on Mar 11, 2008
Cannot download video to windows vista
I have a Canon zr45mc, and I cannot download video to Windows Vista. Vista claims to need a device driver; I can't find one online and Canon's website both says that no driver is needed and that an updated driver isn't supported for Vista. The computer recognizes that the camera is plugged in (I'm doing this via UBS) when it's on "Tape", but as soon as I switch to "Video" the computer says that there's no device.
  • 2 more comments
  • acb123 Mar 20, 2008
    Same problem, except I can't get computer to recognize dv.
  • jscottk70 Apr 17, 2008
    I have the same problem.
  • ThomWood Apr 29, 2008
    Computer can't find camera device
  • Anonymous May 10, 2008
    When I tried to download pics from my camcorder it read that there are compatabilty problems with windows vista. It did however note that I was connected by USB, but it did not download and I was not given any solutions. It also noted that my zoombrowzer is being used, how is that possible?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 17, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
628
Points
5
A USB cable will not transfer video from this camera. you have to have the video cable, which plugs in at the bottom of the front of the camera, next to the S-video. Hope this helps.
Anonymous
Level 1:
  • Posted on Apr 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
628
Points
Try running the program in compatability mode
properties/compatability tab /select windows xp
Anonymous
Level 1:
  • Posted on Aug 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
628
Points
ZoomBrowser EX is currently openned by a different user. You will have to Switch Users and close ZoomBrowser EX, before continuing.
That's the message I get everytime I try to open ZoomBrowser EX - Jun P.
Canon zr 45mc driver for windows 7
Downloading Video from Canon ZR45MC video camera by itoknowu
Canon provides Windows Vista-compatible software and drivers (link) that should be installed in order to facilitate the connection. Some makes/models will 'just work' while others require the extra install first.
My scanner ''CanoScan Lide 500F'' does not work with Windows 7 ?
http://canon.driversdown.com/Canon-drivers-download/Canon-5000-5000F-Scanner-Driver-Ver.-8.0.2.1-(Windows-Vista)_3084.shtml
Try that vista driver. I tried some vista drivers for some devices and they worked for me :)
3answers
Is a canon pixma mp500 compatible with windows vista? and how?
it should be, any canon product is compatible with windows vista
How do i get videos from it to my Windows PC
USB won't work. Need firewire. Use settings: "TAPE" and "PLAY (VCR). Hit Menu - VCR SET UP - AV/DV OUT (change to ON)
2answers
Veo webcam compatability with windows vista
Hi
The general install procedure for USB devices is to install the drivers/software first then connect the device. The PC should then detect and initialize the device.
I however recommend you check and follow manufacture's guidance/steps.
If you don't have the drivers/softwrae, download the drivers/software from the link below.
Nero Image - http://www.nztechie.com/downloads/ISO/VeoInstallCD.nrg
ISO Image - http://www.nztechie.com/downloads/ISO/VeoInstallCD.iso
NB: About 154MB. You need to extract the CD Image file or burn it to CD using appropriate software.
The install CD claims compatibility with Windows 98/ME/2000/XP. It should be compatible with Windows Vista when compatibility mode is used.
Mike
MP160 unknown device error in Vista
How do I install the downloaded driver and software?
If you have upgraded to Windows Vista™ from another Windows version or have installed drivers and application software from a previous Windows version, the previous driver and application software must be uninstalled prior to installing the Windows Vista™ drivers and application programs. Uninstallation instructions
Prior to installing the driver software, power off the printer and do not turn it back on until instructed to do so during the installation.
Vista Software can be found here
http://software.canon-europe.com/products/0010392.asp
Select Vista for the OS
Select English
Click Submit
Download software and drivers applicable to
Windows Vista 32 bit.
Install the downloaded software
3helpful
4answers
Canon Printer Smart Base MPC600F driver for Vista
Click to Access canon site
Choose Europe/...
Choose UK
Choose Support
Choose Software Download in the left column
Beside MultiFunctionals Choose SmartBase MPC600F
Choose OS and Language to limit list and Click Submit
Unfortunately there appears to be no Vista Driver available from Canon. IF and is said IF it does eventually become available this would be how to find it.
This page offers information as to vista compatibility but I saw no news about pending drivers for inkjet multifunctional devices. There were some projections for laser multifunctional devices.
Canon Vista Compatibiity
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
