Do you mean you do not own any physical keyboard or that your keyboard strokes wont register in the game? Try going in the controls menu to assign controls to the keys you want. Maybe your game can't play on a keyboard and requires a certain game controller.Do you mean you do not own any physical keyboard or that your keyboard strokes wont register in the game? Try going in the controls menu to assign controls to the keys you want. Maybe your game can't play on a keyboard and requires a certain game controller.
You can't post conmments that contain an email address.
How to Relearn the ETC (electronic Throttle Control) If the battery is disconnected, the electronic throttle control (ETC) may forget the zero throttle position too. If you find that your CTS runs poorly, you will have to have the re-learn the position.
To do this, Turn the key to the run position with the engine off for at least three minutes.Then turn the key to the off position.Start the engine and let it idle for 30 seconds.Turn the engine off and restart. The learning process should be complete. I found this process on the website cadillacfaq.com
seems something wrong with the Electronic throttle control (ETC) which is an automobile technology that electronically "connects" the accelerator pedal to the throttle, replacing a mechanical linkage
There is no mechanical linkage between the accelerator pedal and the throttle valve with electronic throttle control. Instead, the position of the throttle valve (i.e., the amount of air in the engine) is fully controlled by the ETC software via the electric motor.
- you better have the ETC immediately serviced by an approved Toyota-shop Electronic throttle controlElectronic Throttle Control
there are a few things that can cause that there is a black box mounted near brake booster that controls the drive by wire system.the throttle body could be bad or there has been a lot of problems with the wiring harness. you should have the codes read before you go any farther.
IF YOUR UNIT IS A WKL IT SHOULD HAVE A SENTRI III CONTROLLER(BOARD) THAT HAS A LCD DISPLAY GREEN NUMBERS ON IT WITH BUTTONS(SET, WARMER, COLLER) IF SO THE ONLY OTION IS TO REPLACE THAT BOARD, A VERY SIMPLE PROCESS 10 TO 15 MINUTES MINIMU TOOLS, CONTACT BREEZAIRE AT 858-566-7473 THEY WILL SELL YOU A BOARD OR CONECT YOU WITH A DEALER TO BUY THE REPLACEMENT BOARD ARROUND $150 APROX
Most games have a option menu that allows you to set in-game joystick contols. So go to option and go to joystick.. and you can most likely set your keys there. Some games have this, others do not.
