It sounds as if one or more of the drum supports, which are springs or shock absorbers, have become detached or are in some way damaged. You would need to take the back and top off the machine to check this. Otherwise you will have to call a service engineer.
Alternatively, if this is a brand new machine, the reason is that the transportation fixings have not been removed. These are typically two or more steel rods that hold the drum in place, and have to be removed when the machine is installed, and before it is used, If they are not removed there is no damping of vibration as the drum is not free to move on its flexible supports.
Testimonial: "Thanks that was really helpful"
not spinning
I need the number for a replacement belt for an Indeset 1100 WB111
