Question about Olympus FE-230 Digital Camera
Switches off when USB connected to PC
When I connect the USB to the camera it will not switch on. If I switch on and then connect the camera to USB cable supplied it is OK but as soon as I plug the USB into the PC the camera switches off.
I can't get the pictures off the card at the moment.
    Genius:
  • 1,554 Answers
Try another usb connector on the computer.
the camera or usb connector may be damaged.
you can always get a cheap memory card reader for your computer as a fix.
Posted on Mar 25, 2008
6ya staff
SOURCE:
Where do I find drivers for a Belkin USB Hub?
Hi, when you connect a USB hub, operating system (i.e. Windows, Mac, etc ) it should install automatically a generic driver for it, only when you connect a device to USB hub, in example, a camera, you have to install drivers for that specific device according to its installation guide.
May 09, 2016 | Belkin Computers & Internet
My canon sd 800 is switches off while importing pictures on my pc
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Apr 03, 2013 | Canon PowerShot SD800 IS / IXUS 850 IS...
Camera turns itself off when trying to trasfer pictures to my computer
Consider NOT connecting your camera to your computer.
Jul 01, 2012 | Kodak M522 Digital Camera
My samsung nv15 camera will not load pictures on to pc when plugged in via usb port the camera switches on with opyions of 'computer' and 'printer' but neither will open to allow me to see pics instead...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 06, 2011 | Samsung NV15 Digital Camera
Can't connect to pc through the usb port. I used to be able to connect the camera to any pc by connecting with the cord to an usb port - all I did was connect and switch on the camera and it gave me the...
I highly recommend that you instead consider using a card reader to move the photos or videos to your computer. Card reader's do not require software (although Windows 98 and earlier may require drivers), are very inexpensive, are much faster downloading files from the camera, do not use the camera's batteries during the download, and are much less prone to file corruption of the photos during the download.
Really, it would be better for the camera user if one of these was included with the camera instead of the cable and bundled software.
You place the camera's card in the reader, plug the reader into the USB port, and your computer sees it as a hard drive. You simply copy/paste or drag/drop your photos onto your hard drive. For this simplicity, most professional photographers utilize card readers exclusively. You'll save yourself a lot of heartache if you convert to using one of these. Also make sure that you get a reader that is clearly stated capable of reading your card, particularly if you use SDHC, XD, CF, or MS cards.
click the below link to see a customer who is satisfied with this solution.http://www.fixya.com/support/t4819673-new_samsung_sl_620_camera_dvd
Thank you!
Jun 01, 2010 | Casio Exilim Pro EX-F1 Digital Camera
Switches on but immediately switches off.
Hi
There may be any of the three fault in your device.
1) Battery got died up (Need to replace) 2) Your Charger may be faulty, try to charge it through USB Cable by connecting it to your system (computer), I case your camera have facility to charge it from computer. 3) ON/OFF switch may be malfunctioning (shorted).
Else, Your device need service (repair)
Have a nice day Rating the solution is highly appreciated.
Mar 06, 2010 | Fuji FinePix A920 Digital Camera
Switches off when connected to computer
Sep 16, 2009 | Kodak Easyshare C813 Digital Camera
Not connecting to pc
try to download a driver for your camera
Jan 12, 2009 | Samsung Digimax A50 Digital Camera
CANON IXUS 75 Cannot upload photos to pc anymore!
OK, I'VE GOT ONE IDEA THAT MIGHT WORK. IT'S WORTH A TRY. DO THIS. TURN YOUR COMPUTER OFF> CONNECT YOUR CAMERA>TURN THE CAMERA ON>THEN, TURN YOUR COMPUTER ON AND SEE IF YOUR COMPUTER WILL RECOGNIZE IT THEN. THIS SHOULD CAUSE THE COMPUTER TO RECOGNIZE THE CAMERA. GOOD LUCK AND I HOPE THIS WORKS! IF YOU NEED MORE HELP,REPLY TO ARCLIGHT1217.
Oct 14, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Olympus FE-230 Digital Camera Logo
Top Olympus Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you an Olympus Camera Expert? Answer questions, earn points and help others
