1. Open Menu
2. Go to the "Ajustes" (it's Settings on spanish)
3. Click and open Ajustes (Settings)
4.Scroll to the "Lengua" (it's spanish word fro language)
5. Press and choose English
Hope I was helpful.
Voice Mail is a network feature. Please contact your service provider for configuring the password, or removing it, and to change the Voice control from Spanish to English.
If your Phone Display is in another language other than English, the following instructions will apply: Changing the display language Note: This is the only Language configuration for this phone.
Press the {MENU} button on the handset.
Use the Up and Down arrows on the Handset and select the menu "Handset settings", followed by the {OK} button.
Use the Up and Down arrows on the Handset and select the menu "Display settings", followed by the {OK} button.
Use the Up and Down arrows on the Handset and select the menu "Change language", followed by the {OK} button.
Use the Up and Down arrows on the Handset to select the desired setting.
Once the desired setting is found, press the {OK} button, followed by the {OFF} button.
go here and make first language english and next SPANISH
follow this pattern settings->phone settings->language settings ->phone language->english type this word by word in translate and do it in your phone it will be back to english...
Press the "Menu" button and locate the "Settings" (should look like a spanner), press "Ok" or "Select", once it's opened, locate the "phone settings" (it looks like a phone receiver or like a mobile handset) using the up and down key, open it and then the again select the first from the list (that should be theLanguage settings), once it's opened, you'll see the english language written in english as "English", select it [or you can just select "Automatic" if it's default language was "English"]. Now, the language of your mobile will change back to English.
If you need further help, let me know with more details.
Display Language
You can select either “English” or “Spanish” as the display language. The factory
preset is “English”.
• If you select a language you cannot read, change the display language again
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [up]
or [down], then press Select.
3 Scroll to “Change language” by pressing [up]
4 To change from English to Spanish, press
Español.
To change from Spanish to English, press
English.
• The display changes to the selected language.
• You can also select a language by pressing [up] or
[down].
5 When Spanish is selected, press Salvar, then press [OFF].
When English is selected, press Save, then press [OFF].
You can follow the below mentioned steps to change your language settings,
1. Press the FLASH/program button until the screen displays 1ENG 2FRA 3ESP.
2. Use the CID/VOL (3 or 4) button or the handset number pad to select 1 (English), 2
(French), or 3 (Spanish). The default setting is “1ENG”.
3. Press the FLASH/program button to confirm and to advance to the next menu
feature.
Referrence:
http://www.home-electronics.net/ge/pc/IB/27831GE1_IB.pdf
To return the base announce language to english press and hold the skip button for two seconds.
To change the display language in the handset press the flash button, then use the CID button to sellect english, then cycle thru the rest of the menu by pushing the flash button until done.
Hope this helps!
