You need to press button A to enter the time setting mode and then press C.
If you have lost your instructions, you can get instructions from the Amitron web site.
Copy
"www.armitron.com/watch_instructions.asp" into your search engine and
you will see a list of illustrations of watches and associated
instructions.
Choose
the one that looks like yours and download the PDF file.
These are the instructions posted on the Armitron website. I hope they help.
1. From Time Telling Mode, press 'B' twice to enter the
Alarm Mode.
2. Press 'A'. Alarm Hours flash. Press 'C' to advance the
Alarm Hour.
3. Press 'B'. Alarm Minutes flash. Press 'C' to advance the
Alarm Minute.
4. Press 'B'. Alarm Time Zone flashes. Press 'C' to select
either Time Zone 1 or Time Zone 2.
NOTE: The Alarm is available in one Time Zone only.
5. Press 'A' to end set sequence.
6. Press 'B' to return to Time Telling Mode.
ACTIVATING THE ALARM AND HOURLY CHIME
1. While in Alarm Mode, press 'C' to activate the Alarm.
The Alarm symbol appears to indicate the Alarm will
sound at the preset Alarm Time for 20 seconds or until
'A', 'B' or 'C' is pressed.
2. Press 'C' again to activate the Hourly Chime.
"CHIME" appears to indicate the Hourly Chime will sound
every hour on the hour.
3. Press 'C' again to deactivate the Alarm.
4. Press 'C' again to deactivate the Hourly Chime.
5. Press 'B' to return to Time Telling Mode.
Welcome to Fixya,
The Armitron WR165 is a digital watch that includes a 24-hour alarm, hourly chime, stopwatch feature, countdown timer and is water resistant up to 165 feet. With a rubber wristband and rugged style, the watch is meant for outdoor enthusiasts and athletes. The WR165 can be found online, in some sporting supply stores and in certain department or general home stores. Setting the Armitron WR165 only takes a few steps to perform properly.
1 - Push the top button on the left-hand side of the watch until the seconds flash on the display.Press the top button on the right-hand side to zero the seconds.
2 - Push the bottom button on the left-hand side of the watch until the hours flash and then the top button on the right-hand side of the watch to increase the hour on the watch display. Note that "PM" will appear on the watch display for PM times, but there is no "AM" indicator on the display.
3 - Press the bottom button on the left-hand side of the watch until the minutes flash on the display.Press the top button on the right-hand side of the watch to increase the minutes on the display.
4 - Repeat to set the month, date and weekday on the watch. Press the top button on the left-hand side of the watch to return to time mode.
5 - Press the bottom button on the left-hand side of the watch to enter the stopwatch mode. Press the top button on the right-hand side of the watch to start the timer. Press one more time to stop timing. Press the top button on the left-hand side of the watch to reset the stopwatch to zero and the bottom button on the left-hand side of the watch to return to time mode.
6 - Press the bottom button on the left-hand side of the watch twice to set the alarm. Press the top button on the left-hand side of the watch until the hours flash on the display. Press the bottom button on the left-hand side of the watch until the alarm number flashes. Press the top button on the right-hand side of the watch to choose Alarm Time 1 or Alarm Time 2. Push the bottom button on the left-hand side of the watch again until the hours flash. Push the top button on the right-hand side of the watch to choose the alarm hour, followed by the bottom button on the left-hand side of the watch to change to minutes. Press the top button on the right-hand side of the watch to advance the alarm minutes. Press the top button on the left-hand side of the watch to set the alarm time and the bottom button on the left-hand side of the watch to return to time mode.
I hope this will help you.
Thank you for usinf Fixya.
Been searching for this forever. Found it so thought I'd share..
To set time and date etc.: Starting with the watch set on the time (if not already, use the mode switch until the time shows),
Push the mode button 3 times ...
•the first takes you to stopwatch mode
•the second takes you to setting the alarm time
•the third takes you to the settings (and the Tuesday [TU] and seconds flag will flash)
Then use the lap/reset button to advance through each of the items (minutes, hour, date, month, day of week). When on each of them, you can push the start/stop button to advance through the details (minutes, hours, etc.).
When on the hour setting, it advances through 12-hr AM (A), 12-hr PM (P), or 24-hr (H). If you keep going, it just recycles back through. Switching between 12 hr and 24 hr (military) systems is done as part of the settings for time and date.
Whenever you have everything set the way you want it, just push the mode button and it goes back to normal time keeping.
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
For the alarm: If you want to use it (I think both it and the light use battery faster than when not used), you set it by pushing mode button twice, as indicated above, then go to hour or minute setting by pushing the lap/reset button, and advance to the time you want by pressing the start/stop button. Pushing mode will take you back to normal time again.
To turn alarm on or off, hold lap/reset button in and at the same time push the start/stop button. Alarm icon will show on or off. When you release the lap/reset button, it will revert to normal time.
If the alarm is on, at the designated time it will start beeping for awhile or until the lap/reset button is pushed (off) or start/stop button (snooze).
