Washing Machines Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore 80 series washing machine will fill up with water, then nothing happens
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
449
Points
Kenmore Ultra Fabric Care Heavy Duty 80 Series washing machine (Model # 110.92389200; Serial # CF 1122814) went through the wash cycle completely, but rinse not the rinse cycle. Motor was going but washer not spinning. Also smelled something like burnt rubber. Could the belt have gone out? Is this something that I can fix myself?
Kelly
Level 3:
  • Master 3,740 Answers
  • Posted on Mar 18, 2010
Kelly
Master
Level 3:
Answers
3740
Questions
Helped
2163373
Points
12091
This can be one of three things:
1. The pressure switch / level control
2. The motor / motor switch
3. The timer assy.
4. The lid switch is not functioning.
The most probable suspect at this time would be the lid switch. As you just open or just close listen for an audible "Click" of the lid switch. If there is no click you will need to have the lid switch replaced. Note: The unit will not agitate or spin if the lid switch has failed.
You did not mention if the unit would drain and spin or not. That information would help in isolating the problem. Also the exact model number please. Example (110.XXXXXXX)
If it drains and spins then the most likely suspect(s) would be:
(in order of precedence)
1. The pressure switch / water level control.
2. The timer assy
3. The motor
All of the above 1, 2 and 3 would have to be troubleshot with a meter before replacement.
Thanks for using FixYa.
Kelly
1helpful
My kenmore 80 series washing machine makes a horrible noise and cold side fills about half speed when filling with water. What should I check?
For the slow water issue, you will need to replace the water inlet valve. Here is a link to the part.
Could you describe the noise and where it is coming from?
1helpful
Kenmore 80 series fills with water then doesn't
the lid switch under the control panels bad replace it and it will again wash,they just unsnap out of the top of the cabinet after you remove the control panel
My Kenmore HD plus 80 series fills up tub slowly, starts cycle before its full.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 13, 2011 • Dryers
Kenmore hd 80 series,extra capacity plus. cold water will not fill tub?
heatman101
Kenmore 80 series
Look inside the pump. Smething might be in it. If you incorrectly installed the couplings too tight against the tranny or motor then the resulting bind will cause the problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Top Washing Machines Experts
john h
