Please see this link for an explanation of the OE code:
http://www.whitegoodshelp.co.uk/wordpress/lg-washing-machine-error-code-oe/
SOURCE: INTELLOWASHER LG BRAND HELP
rebalance the load inside the tub..you may need to remove some of the items..check the user guide for load levels again
SOURCE: LG washing machine displaying error
It was actually NEC (apologies), I was able to fix as 'OE' means there is a problem with draining water, after manually draining water from wachine i removed the draining pump and pulled it apart a hair elastic was wrapped around turning mechanism of motor after removing that and putting back together the washing machine now works as good as new.
SOURCE: LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
SOURCE: what does oe mean on my washing machine display
"OE" code in your washer indicates a Drain error.
This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
SOURCE: my washing machine, which is a LG Intello Washer
That is actually a DE (drain error). Clean out the filter, located behind the access door on the bottom left side on front of the machine. If there was nothing in the filter, replace the pump motor.
Testimonial: "Thank You, it worked. Made the wife very happy. Thank you again."
Hello & Welcome to FixYa
OE is a drain error and is displayed when the
washer is unable to drain water. Please check the drain hose and drain pump
filter for any clogs to clean the error. Please get back to me if you have any
other questions.
Kevin
other questions.
Kevin
