• Press [2nd] [MODE] and scroll to FLOAT.
• Press
the right arrow key until the number of decimal places needed is
highlighted.
• Press the [ENTER] key.
For 2 decimal places, 2
should be highlighted. All answers will then be rounded to 2 decimal
places.
• Press [2nd] [QUIT] to return to the home screen.
SOURCE: how do i change from whole numbers to decimal
Press the [MODE] key repeatedly until you reach a setup screen that shows FIX SCI NORM with 1 beneath Fix, 2 beneath SCI, and 3 beneath NORM.
Press [1] to select (FIX) and follow it by the number od decimal digits you want (2 or 3 seem about right).
SOURCE: Why can't I change the number of decimal places on
It seems to me that you are omitting a step: see screen capture from manual (step 4). Hope it helps.
SOURCE: Default decimal settings
Your BA II PLUS stores numeric values internally to an accuracy of 13 digits. However, the numbers it displays depends on the number of decimal places to which you have it set (choice of 0–9 or floating decimal). To set the number of decimal places displayed to three: hit [2ND][FORMAT][3][ENTER]This setting also continues indefinitely (even though the calculator is turned off and on) until it is changed.
SOURCE: I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183
Introduction
This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation.
Instructions for standard format
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
One adjustment is important before we get started. By default the 12C displays only two decimal places. This is not enough. Personally, I like to see five decimal places, but you may prefer some other number. To change the display, press "F" and then the number of decimal places you wish to display. I would press "F 5 " to display 5 decimal places. That's it, the calculator is ready to go.
