There should be one cord from the wall to socket marked LINE on answer machine, then one cord going from socket marked PHONE on answer machine to your telephone.
Depends on the setup, but generally if you look at the back of the machine there should be two phone jacks, one says 'Line" the other says "Phone" Connect the phone cord from the wall jack to the "Line" plug and the cord from the base of the phone to the "Phone" plug, and you machine should work. The power supply will also need to be plugged into the base of the machine and then into a wall outlet.
We know that electronic mosquito zappers usually come exactly in the form of a badminton racket, and quite similarly have a net woven over its top circular frame; whereas the handle part consists of an electronic circuit and a battery pack integrated with the net assembly. The net structure is primarily made up of three layers of metal mesh and is rather a complicated assembly. The inner central layer is actually the "hot" mesh and is terminated as a high voltage source from the circuit enclosed in the lower handle area. The outer two layers are simply connected with the negative of the battery and constitute the ground for a return path to the central "hot" mesh line.
The fax machine should have two places on the back where you can plug in a phone cord. One of these is the input: where the cord from the wall goes, and should have either "in" or a picture of a wall phone outlet next to it. The other is used as a line through the fax machine and should have a picture of a phone or "out" next to it. Ideally, you would plug the fax machine directly into the wall and then your phone/answering machine into the "out" plug on your fax machine.
When in auto mode, the fax machine will listen in on the line when the phone rings and if it detects a fax signal (all the whirring and beeping) it will pick up the phone and receive. If there is no signal, it will simply allow the signal to pass through to the phone and answering machine.
This is likely caused by a trouble from the service provider. It is caused by a partial short on the phone line. The service provider can usually test the line remotely when you call the trouble in. Occasionally this problem is caused by faulty equipment(phone, answer machine, modem, etc.), bad line cord, bad outlet or bad building wiring. Inside the outside telephone interface box there is a modular test jack that has a short line cord connected. Remove this line cord and connect a standard telephone to test the phone line. Make a call to your number, if the problem occurs with the phone connected to the test jack, then the problem is with the service provider. If the problem does not occur with the phone connected to the test jack then the problem is in the building wiring, outlets, line cords or devices connected. Use a process of elimination to determine where the problem is. Example: disconnect all phones and devices and line cords, make test call with one phone connected, if problem continues inspect outlets and wiring.
The phone will do this if it isn't (or thinks it isn't) connected to a working phone jack. Try a known good phone (corded type) in the jack to verify that in fact there is dial tone there. Also make sure that the line cord is firmly plugged in at both ends until the latching tabs snap into place. Sometimes it's just a poor connection because the plug isn't all the way in. You can also try another line cord. Bad ones do pop up sometimes.
If everything is correct with the phone jack, take the phone back to the store for an exchange. You have a dud.
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass >then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone? >let me assume you only have one number for fax and phone.. >check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack. >next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax. >also check if auto answer is on in your fax >you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings >also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
If it doesn't, replace the line cord and try again.
If it does ring, check the optioning to make sure it is set for, say 2 rings.
Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
If everything is correct, replace the answering machine.
You should have two jacks on your answering machine. One should be marked "Line". Plug the telephone cord from your wall into this one. The other jack should be marked "Phone". You will need another telephone cord to plug into this and then connect the other end to the phone.
