I have a Haier window unit that is about a year old. During a power surge the safety power cord tripped and will not reset. I know the unit still works because when I hold down the reset button on the cord the unit will operate normally. Is there anyway to replace or bypass this saftey device without creating a fire hazard?
You can by-pass it by simply connecting the 2 wires together. Obviously the safety it is supposed to protect you from will not work, but it can get you by instill a replacement can be found. It seems like the surge burnt the coil out on the switch. If you are conscious of the heater and what its going ,you should be safe. They made these things a long time without a trip switch on the cord. It just requires some common sense.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
