Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Rate me, please.
Can anyone please post the video about the instruction of setting time? I did know how to set the time but the minute-hand doesn't move. Why? Thank you for kindly help.
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would
think.
First, a couple things you need to know and remember.
1. The watch has a
safety feature which requires you to press the touch button on the right side
of the watch before you can do anything as far as touching and changing
anything. If it did not, every time you
accidentally touched the dial something would change.
2. Touch means you
are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you
must first press the touch button on the side.
The word touch will light up (display) inside the watch on the right
side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the
bottom of the watch. You need to be
touching the watch dial and these stones at the same time to do anything we are
about to do.
While touching and holding the bottom of the dial you may
see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you
will then see the word hold at the top and then the hour of the time
flash.
To increment the time or decrement the time, touch the right
side of the dial or the left side of the dial.
When you have arrived at the current hour, touch the hour at the top
again and the minutes will begin to flash.
Continue to set all settings in this manner until you are
satisfied. Touching the top to move to
the next setting and right or left of dial to go up or down.
When you are done.
Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the
time, chrono, alarm etc. To see time if the screen saver is on, touch the left
side of the dial. Touching this
repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will
Cool feature,
This watch actually has two displayable times you can use if
you travel often to a second time zone.
Press the touch button on the side and touch the right side of the
dial. Touching it for a second or two
will display the time of the second time zone.
Touching and holding for a couple more seconds will cause the T2 on the
display of the left side of the watch to flash and eventually switch to the
second time. I am thinking that touching
the bottom of the watch while displaying the second time should allow you to
set this time also.
The process may be less complicated than you would
think.
1. The watch has a
2. Touch means you
To change the time, day, date etc, on your watch you
side of the dial.
about to do.
flash.
When you are done.
Day to day use,
Cool feature,
set this time also.
Dont have that particular watch, but try this.
think.
1. The watch has a
2. Touch means you
side of the dial.
about to do.
flash.
When you are done.
Day to day use,
Cool feature,
set this time also.
