Hello Winston;
Even the new number you provided does not cross. Could your saw be a PM3216, model 11-600032-33? That does cross here:
McCulloch MTD
Chainsaws 32cc-35cc
and with better detail here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/MCC/11-600032-33-Mac-3216-06%2F93-IPL-211229/139.11-600032-33-Mac-3216-06%2F93-IPL-211229.1.59.1.html
See the "General Assembly" print; item 23; pn 224242-02.
M & D Mower
http://www.m-and-d.com/index.html
Has the above item available through arinet reasonably.
It follows:
http://arinet.lookupparts.com/AddToBasket.aspx?Qualifier=MCH&Name=224242-02&Quantity=0&SellerId=1017594&Username=Default
I am going to close this. We can continue to converse as before.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Typical fuel system and a couple of tips here (If this is indeed a MTD McCulloch I suggest a ton of photos):
http://www.fixya.com/support/r3706813-2_...
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
http://www.ordertree.com/modelinfo/MCC/1...
Lou
When the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
The pressure side of the primer returns displaced fuel to the tank as it is depressed.
To get your manual for your McCulloch chain saw, you need to call 1-800-521-8559, ask for parts, than ask for a PDF user manual,you will need the model number of the saw..
It will be e - mailed to you for FREE.
1-800-521-8559
MONDAY - FRIDAY - 6:00 AM - 4:30 PM (MST)
www.mccullochpower.com
Please take time to rate me
The part I'm looking for mc9142310002 (I evntually found it). I'm now looking to source the part from a dealer in my area. I'm in Mississauga Ontario Canada (l5l2r3). MIssissauga is a suburb of Toronto Ontario.
I can't seem to find a local supplier
Thank you for your time and effort in trying to help me.
It is much appreicated
Winston
Absolutely zero of the numbers provided leads to anything except this FixYa question. Power Mac 32?? No model 600035-33 with any prefix. No McCulloch parts 46704-59. All McCulloch IPLs can be found here: McCulloch IPLshttp://www.ordertree.com/modelinfo/McCul... I have spent all the time I am going to without some updated input from you below. Lou
