Werfault.exe -application error\r\n
You can try to disable this service by following the below steps:
Step 1: Open your computer's Control Panel by selecting "Start" > "Control Panel" from your computer's Start menu.
Step 2: Choose the "System and Maintenance" > "Problem Reports" menu option from the Control Panel menu.
Step 3: Select "Change Settings" > "Advanced Settings" from the Problem Reports program menu and turn off the automatic problem reporting feature in Windows.
Step 4: Exit the Problem Reporting application by selecting "File" > "Exit" from the File menu. Werfault.exe will now only run on your computer in the event of a catastrophic application problem.
If disabling the application does not work, you should keep in mind that many malware programs can show up on your system as seemingly legitimate files by using file names that are very similar to those of legitimate files. Whenever you are in doubt about a particular file, always scan your system for viruses.
This stops me from accessing I Tunes
