Sewing Machines Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to sew tab tops on a thick curtain which is lined have got a larger needle and decreased tension but its not working help Using a Brother x3600 sewing machine
Anonymous
Level 3:
Genius:
  • Master 1,116 Answers
  • Posted on Mar 17, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1116
Questions
0
Helped
371314
Points
3174
Put the tension back to the normal setting - around 4.
Lengthen the stitch to accommodate the multi layers.
When you are sewing and come to a thicker section, stop with the needle down, lift the presser foot and place a folded scrap of fabric under the back of the foot to keep it even. Lower the presser foot and continue sewing.
I have a Consew 206rl and it won't sew on double layers of leather but sews fine on single layers. What adjustments can I make
Sewing on double layers of leather can be challenging, and it's important to have the machine properly adjusted to handle the thickness. Here are some adjustments you can try:
  1. Needle size: Make sure you are using the correct needle size for the thickness of your leather. A larger needle may be required to penetrate the layers.
  2. Tension: Adjust the tension of the upper thread. If the tension is too tight, it can cause the needle to break or skip stitches. If it's too loose, the stitches may be uneven.
  3. Presser foot pressure: You mentioned you have already adjusted the presser foot pressure, but to clarify, turning the adjustment screw clockwise will increase the pressure, while turning it counterclockwise will decrease it. You may need to increase the pressure for thicker materials.
  4. Stitch length: Increase the stitch length for thicker materials. A shorter stitch length can cause the machine to struggle to sew through the layers.
  5. Speed: Slow down the speed of the machine when sewing on thicker materials. This will help the machine to handle the thickness and prevent skipped stitches or broken needles.
If none of these adjustments work, you may need to take the machine to a professional for further inspection and repairs.
I have a Brother invo NQ3500. The thread comes out of the Needle bar thread guide while I'm sewing and then becomes unthreaded. Help! Colleen
Are using embroider table?
Suspect uneven feed of top thread from spool. Check that top thread spool is correct orientation and spool cap is larger than spool.
See page B-25.https://download.brother.com/welcome/doch100190/888g00_g02_g04_g05_g06_om03en.pdf
With presser foot up and needle up, select tension 4 and rethread top thread. Then make a long slow steady pull of top thread. It should advance smoothly through needle eye with even tension (no snagging). Now lower foot and again make long slow steady pull of top thread. It should advance smoothly through needle eye. Note difference in no tension (foot up) and tension select 4 (foot down).
1helpful
2answers
1helpful
Iam sewing seats. but the threed stared braking at the needle & it want saw.
Most likely, it has to do with incompatibility of the needle, thread, and fabric. The force of the needle penetrating the fabric multiple times is actually causing the thread to (wear &) fray and eventually break. There are needles with larger grooves that tend to protect the thread during stitching. Some may recommend a Top Stitch Needle (Home Machine Needles Superior Threads Why Topstitch? The Topstitch needle is the most common needle type used and recommended by professionals and educators. We recommend the Topstitch for piecing, quilting, embroidery, appliqu?, and construction. These needles are available in four sizes to accommodate all thread types, including metallic threads. The Topstitch needle has a larger eye and deeper groove. It is often referred as the MAGIC NEEDLE. It really does make a difference in your sewing experience.)
Why Use Topstitching Needle
Also, if the thread is a tight fit through the needle eye, it will also tear the thread. Make sure that the thread will slip easily through the eye. Go to a larger needle, instead of 90, try a 100.
Be sure to use a brand-new needle.
All About Needles
The Parts of Sewing Machine Needle
You may also consider changing the type of thread you are using. Go with a stronger thread, ie polyester, rather than cotton. Cotton will shred and break easier.
You will probably need to re-adjust the thread tension. If it is too tight, it will also break the thread. If you are using a heavier weight of thread, you will need to adjust both the upper and bobbin tension to accommodate the heavier thread.
Bobbin Tension How and Why Tension is Adjusted
If you sewing fabric that is sticky, ie vinyl, oilcloth, you should try to use a roller presser foot, a teflon presser foot, or a walking foot to help the fabric move with the feed dogs.
Sewing Heavy Fabric with NON Heavy Duty Sewing Machine SEWING IN GENERAL
Tips
Sewing through many thick layers of fabric Sactin
http://www.kollabora.com/q-a/sewing-denim-and-thick-fabric
14 Fantastic Sewing Tricks and Tips Making the World Cuter
How to Sew Upholstery DoItYourself com
2answers
What is the factory tension setting for the Brother LS-2125i sewing machine?
you probably wont find it listed anywhere as it is from experience and changes with different material thickness and needle size
SO how to set tension
thread the machine and adjust the tension until you feel a drag on the thread
now thread the needle and sew a piece of scrap material
if the thread bunches up underneath then increase the thread tension until it sews properly
if the bottom thread is pulled to the top or the thread keeps breaking loosen ti off a bit
when the stitch is being properly formed , both bottom and top threads should meet at the center of the two materials being sewn
Top thread keeps breaking
Don't ship it back and the problem is not the tension settings. Even on the tightest setting the thread should not break. Most likely the machine is not threaded correctly. Possibly, you are using too thick a thread or a needle that is too small.
Solution back to basics:
1. verify that you are not using upholstery thread. Use a standard cotton poly mix.
2. the bobbin thread should be the same as the top thread.
3. consider watching a video showing the machine being threaded and make sure the needle is in the top position.
4. sew a test pattern on a normal weight fabric like an undershirt - avoid very thick material.
If this solves your problem then change one item at a time. Use a heaver thread if that is what you want. If it works ok then go to a thicker material, etc. Do not change two or more things at a time..If you have a problem it makes it hard to identify the source.
2helpful
Similar issue with bunching on the bottom side of vinyl
when sewing thick fabrics and when using thick threads you will usually need to tighten top tension - on most machines to maximum in order for the machine to pull the thread up into the fabric. you must also use a needle which will slide along the thread when thread is through eye of needle (take needle out of machine, put thread through eye and see if needle will pass freely along thread - if not, use a larger needle)
scott.
1helpful
Problem while sewing buttonhole with a thick thread
You will need to use a size 18 needle or even better a size 18 top stitch needle. It has a larger eye.Tighten the tension to about an 8 and try it. You may have to lengthen the stitch length to make it sew satisfactorily.. If it won't work on 8 go to 9 and if it still won't work, wrap the thread around the bobbin winder guide (on the left top of the machine) for more tension. It is very hard to sew heavy duty thread on a household machine.
sewman7
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
