Check for dry solder joints especially on the main power output transistor.
A
blown power transistor will stop the 'Current Drive' from engaging so
if the problem you have is intermittent then it is most likely dry
solder joints.
Hope this helps.
Thgis sounds like a problem that is beyomd the scope of remote diagnosis. Perhaps a trip to a tech would help the patient.
SOURCE: i have a technics su-v660 integrated amplifier.the
Unplug the power, open the case and try to locate some electrolytic capasitors is series with the audio at the channel with the problem. One of them must be blown.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
