Bosch Logixx 8 Washing Machine Model Number E-NR-WAS28466GB /03
Cycles never complete . They get stuck at 1 Minute to complete. machine is out of Warranty . I phoned Bosch tech line up and they said it sounds like a Thermostat / Heating issue. Expert On Uk White goods forum also suggested it is common fault but could be due to burnt or dis connected wiring. Is it easy to open machine ( with power disconnected) and trouble shoot /replace parts. How would I purchase spare parts. If I call a professional in how much are they likely to charge to fix this. Also does anyone know if I can download a technical manual showing parts and part numbers for this model.
Thanks
Found a PDF (MediaFire) manual for you, look for the answer in it !
Bosch Logixx 8 Manual
The heqating element has blown - common problem on our machine - happens around once per year - under warranty - now on our 3rd new heating element !
SOURCE: Bosch Logixx 8 Washing Machine E-NR-WAS28466GB /03
The heating element has blown - this has happened to mine on 3 occasions all covered under extended warranty - regularly occurs about once per year. Now hear is the interesting bit - do you have a microwave near the unit ? If so move it because our Bosch engineer said that the microwaves can have an effect on the unit. If it is true then I will know next year about this time !
