I have the Neff H7871 combined oven and microwave. I can't find where the light bulb is to replace it!
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
That looks very helpful and doable - thank you. Our bulb has just failed and to save pulling the oven out twice could you just add a note as to which replacement bulb we need. Many thanks. John
Sorry, I should have said.......the bulb is a 40w E14 oven/microwave bulb SES fitting. I bought a pack of 10 off ebay for £8.99.
Hope this helps.
Bob.
Hi, I have a quick question, should it be the round type (which most are on ebay) or a oval/mini sasuage (sorry the best desctiption I could think of) type.
p.s. Thanks for the info on where the bulb is and how to get to it.
The bulbs are the more common round "golf" bulbs.
Got the same problem. Thanks for the info. Can you just clarify how I remove the top and bottom trim strips? I don't want to break them and unfortunately the oven is built in above the fridge and below a wooden worktop so very difficult to see what's going on 'behind the scenes'.
The trim strips just pull straight off very easily. Put a finger on each end (left and right), and just pull it towards you. It's held on by a spring clip at each end.
Hi, My Neff 7871 Ceramic Plate broken off during the microwave operation. How do go about ordering the part and fixing the fault.
