Installing Sound/Audio Cards and Drivers
Sound or audio cards, whether it is a stand-alone device inserted into an expansion slot or embedded sound controllers in the motherboard, require specific device drivers in order to function and produce sound. This low-level program is responsible for processing the data between the sound card hardware and the operating system.
Most sound cards are bundled with the appropriate installation CD when purchased. This disc contains a database of the manufacturer’s available sound device drivers at the time of purchase and includes the specific driver intended for the card purchased. Most discs have an autorun installation program that prompts users to start installation. Some only provide a database of drivers and let the Device Manager or Add Hardware applications in the operation system perform the task of installation.
If you dont know the type of driver that you have, please check the following link to help you:
http://www.drivershq.com/driver-update/audio-and-sound/
I hope this is helpful.
Click the link "hp: Modem Driver Installer for Microsoft Windows XP (32-bit)" listed in Resources if you run the Windows XP operating system on an HP computer; for Windows installed on a Toshiba computer, go to Step 3. For all other types of computers running Windows, go to Step 4.
Click "Download" from the HP website and click "Run" to install the high-definition audio (HDA) modem driver package. If the modem device does not work properly after the driver has been installed on your Windows XP computer, go to Step 9.
Click the link "Toshiba Audio Drivers" if you run Windows and use a Toshiba computer. Find your operating system, click the appropriate driver listed and then read the installation instructions on the screen to download the driver. If the modem device does not work properly after the driver has been installed, go to Step 9.
Click the "Start" button and click "Control Panel."
Click "System and Security" and click "Device Manager" under "System."
Click "System Devices" and right-click the "Microsoft UAA Bus Driver for High Definition Audio" device.
Click "Update Driver."
Update the "PCI" description drivers (PCI bus and PCI device) and any modem device that displays an exclamation point to the left of it. If the modem device does not work properly after the driver has been updated, go to the next step.
Visit the computer hardware or operating system manufacturer's website for further support
