You need two thread sources. This can be two spools or one spool and a bobbin on the spool pin.
Make sure the presser foot and needle plate openings are wide enough to accommodate the passing of the needles.
Lift the presser foot and beginning with the thread source to the far right, thread as usual through the right needle, then the left needle.
Make sure to use a straight stitch and you may have to loosen the tension a bit (test).
Hand walk the needles down and back up to catch the bobbin thread. Take all three threads under the presser foot and to the back of the machine.
