see my personal TIPS specially block diagram, if you will see the fuse for every treadmills. 2) Reset the c.breaker too.
3) Reset the c.breaker from your house outlet wall. 4) Test the power cord for wires, break, loose, or burn and repair. 5) Test the power switch, for open or shor. see the diagram attached.
Adjusting the speed sensor:If the calibration does not pass you may need to check the speed sensoralignment.1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
need to flip side and with a wrench 1 / 2 or 9 / 16 loosen the screw of motor base and try to press the down key and if so work you should Lift motor replacement
