Received unit new yesterday. Computer recognizes it, but will not accept it. Also, not charging when connected.
You can also try the advice in this article if your computer is running Windows XP or Vista.
For the recognition problem, you could try resetting the unit. There should be a reset button on the back of the unit. To reset the unit, press and hold the reset button for about 5 seconds.
If the computer still won't give you full access to the Walkman, you can try the recognition solution posted on WarMaiden.org.
For the charging problem, inspect the USB cable to see if there are any frays in it, then try carefully reseating both ends of the cable (one side to the computer and the other to the unit itself). If it still won't charge, I would recommend exchanging it at your retailer.
